I have a iPad based keyboard that has worked perfectly until 2.0. I have tried to change settings to many different languages but all the same output, delete button outputs a "z" z does nothing some letters work fine. I have a black b1443 on lepis 2.0. Any ideas?
Cube Talk9x U65GT_V2.0_en_mod_Lepi_20141206 for CWM or TWRP
physical keyboard settings in input devices not working. Please help!
1 - about keyboard, I've read that it is due to the gesture enabled function, some letter do not work because of the associated gestures
2 - IMEI lost: do you have a Nvram backup? To have the IMEI back you need to download and flash Rom version 1.0, here:
https://drive.google.com/file/d/0B8u...BGWXgyNkE/editif you appreciate my efforts this is the link for any donation:
Can I disable the gesture to get my keyboard working again. Any other workaround.
B) sorry for being a newbe but my IMEI loss. Just download and flash 1.0 then backup the nvram file with sp flasher? How do I Change to a specific IMEI #.
you need to flash rom 1.0 and then you can probably put your IMEI back (or flash back your nvram backup if you made it!).if you appreciate my efforts this is the link for any donation:
Lost physical keyboard settings with 2.0 upgrade
I have no gestures enabled, yet my bluetooth keyboard doesn't not output what i input. tried to change settings in physical keyboard settings with 0 effect. no matter what language i select.
Keyboard worked fine on 1.8. any way to get my keyboard working again.
need a bit more info.
Originally posted by giouncino View Postyou need to flash rom 1.0 and then you can probably put your IMEI back (or flash back your nvram backup if you made it!).
thanks for your help
you could probably input manually your IMEI.
I can't be more detailed than this because I never tested this procedure, but I've read it on an Italian forum.
With ROM 1.0 Baseband info will come back again automatically, then you should be able to put your IMEI back manually.if you appreciate my efforts this is the link for any donation:
Originally posted by giouncino View Postyou could probably input manually your IMEI.
DOES IT HAVE TO BE FACTORY IMEI OR CAN I CLONE MY PHONES IMEI?
Originally posted by bert2 View PostI have a iPad based keyboard that has worked perfectly until 2.0. I have tried to change settings to many different languages but all the same output, delete button outputs a "z" z does nothing some letters work fine. I have a black b1443 on lepis 2.0. Any ideas?
There are no guarantees! Install only through modrecovery! Preliminary backup is required!Attached Files
I don't know how to put imei manually (I'm sorry, as I told you before I don't have further details on it), but once you restored the IMEI you need to backup your IMEI with mobileuncle tool.
You cannot use the IMEI of the phone, only if you have a broken phone you can use that IMEI.if you appreciate my efforts this is the link for any donation:
Originally posted by giouncino View PostI don't know how to put imei manually (I'm sorry, as I told you before I don't have further details on it), but once you restored the IMEI you need to backup your IMEI with mobileuncle tool.
Thank you Lepi
Originally posted by Lepi View PostPatch to v2.0 firmware for those who are familiar keystrokes some letters are more important than black gesture.
i didn't back up my nvram file and don't know how to. after i flash 1.0 how do i manually reenter my IMEI?
There are currently 3427 users online. 1 members and 3426 guests.
