Cube Talk9x U65GT_V2.0_en_mod_Lepi_20141206 for CWM or TWRP
Originally posted by odomike View PostHi everyone,
I am new here though I have had my Cube Talk 9X for w few months and have also downloaded 900SuperSport and now Lepi's ROMs for use on my Talk 9X.
I'd like to know one thing though ... Is there any specific differences between the V2.0.1 and the V2.0.2 or just the theme color (White as in the case of V2.0.2)?
Thanks to all for help.
Differences from V2.0.1 to V2.0.2:
- "13. Improved interface firmware for better readability of the text on the buttons and panels"
- "14. The firmware two launcher - Launcher 3 and ApexLauncher. Left to the user's choice." (in V2.0.1 there is Launcher 3 and Cool Launcher)
- "19. Introduced animation notifications."
- "20. The pre-installed soft: TitaniumBackup, mobileuncle.toolbox, rootexplorer, Terminal, viperFX4." (in V2.0.1 there is no viperFX4)
- + the changes in theme color
You can always download the Apex launcher from Play Store is you want it.
Originally posted by eteles View PostHello guys... What's the best Chinese tab to buy right now? Is the Cube Talk 9x still recommended? Is the low quality screen problem already fixed?
First of all check this post so you know why the screen is grainy in some tablets. I don't know if the screen issue is fixed now. I can only say that my tablet is produced 1430 (14=year, 30=week) and my screen is good.Last edited by Vohukain; 02-05-2015, 17:35.
Originally posted by Vohukain View PostYou can check the ChangeLog from the thead's first post (V2.0.1 and V2.0.2). What I see, there is just minor changes.
Please, do not post multiple times same post. Just wait for answer. The right thead would also be "Cube 9x u65gt" for this question. This thead is for Lepi's rom. And the other thead is for 900Supersport rom.
Originally posted by JugsteR View PostHas that been released on freaktab? Link?
/J
Originally posted by Vohukain View PostHave you heard about search? Here it is: CUBE TALK9X U65GT_V2.0.4B_Lepi_150115
Cheers,
J
I'm trying to follow the steps to install the rom using TWRP.
When I reboot in recovery mode I don't know how to go to the advanced tab to do the necessary wipes.
In my menu I have only, concerning wipes :
wipe cache
wipe data/factory reset
Thanks for your help
Hello,
I'm a newbie to Android tablets and have just bought a Cube Talk 9X and run into the storage space problem. I can't install all the apps I want. I have loads of storage showing free under usb (>10GB) + and external sd card with 32 GB but it always installs to the tiny internal sd.
I was considering reflashing with Lepi's rom but I'm unsure which; 900Supersport's (a Ducati man?) 1.8 or Lepi 2.0. The tablet seems to run Chrome & Opera ok. When I look in "About" to check on versions it tells me Custom built version 1421198781. It is Android version 4.4.2 with kernel 3.4.67.
My biggest interest is increasing the storage size for apps but happy to get root and a better, more English rom if that's easy.
I have no idea what CWM & TWRP are by the way so go easy on me!
Can someone advise what rom to use or even just how to increase app storage? I'll need to be told the step sequence.
Thanks.
Hello and thank you very much Lepi for all the work you've done. I'm new to this kind of stuff, so sorry in advance. I've searched all over, in this thread, other sites etc, but I can't find cwd or twrp for cube 9x anywhere. I have the original rom V 2.0 and B142840*** so I think this rom is right for my system. I have rooted the device already. The main problem I am facing is that it doesn't connect to pc, just charges, so I can't use the flash tool... And the reason i want to flash a new rom is because the battery takes 30 hours to charge from 0 to 100 percent, probably a software problem... Any solutions i can try? Any help at all is appreciated and thanks in advance...
Originally posted by Lepi View PostPatch to v2.0 firmware for those who are familiar keystrokes some letters are more important than black gesture.
There are no guarantees! Install only through modrecovery! Preliminary backup is required!
Originally posted by ADB user View Post
Thanks very much. I had been struggling for a week to update my ROM but I am a layman and searched thro' and tried huge number of sites, forums and youtube, but finally using the process (at DISQUS http://www.addictivetips.com/mobile/how-to-install-a-custom-recovery-to-an-android-phone-device/) and some info. from this page I was successfully able to do it on my Expensive & Feature packed Chinese Phone !
There are currently 2442 users online. 7 members and 2435 guests.
