Cube Talk9x U65GT_V2.0_en_mod_Lepi_20141206 for CWM or TWRP
Originally posted by mattiesrag View PostWould like to donate but cannot do it in Russian. Please give me the English translation. Kind regards.
There is also a Qiwi purse. (+79082695037).
Originally posted by giouncino View Postthere are other and better options:
1 - EZcast dongle + HDMI to DVI/VGA adapter (much better than chromecast and costs only 15€) I'm using it with my TV
2 - USB to HDMI (and HDMI to DVI/VGA) cable adapter
Option 1 works well, I use it every day for transmission of movies to my TV. It's really amazing!
Option 2 should work even faster, but cables are unconfortable.
Going to order them illico presto.
Rgds,
Originally posted by Lepi View PostOnly for tablets with a serial number higher than B1426XXXXXXX!
Hi, my friends. I publish new mod-version U65GT_V2.0.1_en_141230_mod Lepi.
Made on the basis of official firmware U65GT_V2.0_update_aatt_20141215.
ChangeLog:
1. Fully odex except modified applications.
2. ROOT by default Superuser app from Clockworkmod.
3. Remove all software in Chinese.
4. By default the English language during the first boot
5. Modified the boot.img:
a) support init.d through busybox;
b) Permissive mode by default - meaning at least NTFS support in the OTG connector;
c) checkbox is checked USB debugging on first boot, then you can disable.
6. Reduced the minimum brightness level and slightly lowered Auto Brightness.
7. Implemented a system application in the Font Chooser Settings \ Screen to change the font. Development hartec.
8. Boot logo and boot animation by author.
10. Implemented gps.conf file in my editorial for using GPS in Russia. If you do not fit, delete it or edit (\ system \ etc)
11. Black Stock topic, slightly decorated with colored icons.
13. Fixed a bug in the installation script file of the rights of ping.
14. The firmware two launcher - Launcher 3 and Cool Launcher. Left to the user's choice.
15. On the USB connection now button instead of doing Tap on the picture.
16. When you start the dialer immediately opens the numeric keypad to dial.
17. Changed power_profile in the hope of correct statistics of battery discharge.
18. Settings \ For developers introduced Engineering menu and Test menu.
19. The pre-installed soft: TitaniumBackup, mobileuncle.toolbox, rootexplorer, Terminal.
Download:U65GT_V2.0.1_en_141230_mod Lepimd5: c2b53086cd9e44e67218184deb54d92fInstallation Instructions:
Only for installation through modrecovery CWM or TWRP!
Archive firmware to put in the root of the internal or external memory (can be in any directory with the Latin name). Boot into recovery. Make a backup of the current mandatory firmware better on an external memory card. Then make the necessary wipes tab ADVANCED:
1 Dalvik Cache
2 System
3 Cache
4 Data
5 Android Secure
Then select Install (TWRP), specify the path to the file to confirm the firmware and swipe process of firmware. Wait for a successful finish and boot the system. Make settings by yourself.
The first boot lasts a long time, you need to wait patiently and not to touch the display.
There are no guarantees! Risk and assumes responsibility fully by the user.
Preliminary backup is required!
Successful upgrade!
This patch upd_U65GT_201_USB_storage.zip is for those who have downloaded the firmware before 18:00 Moscow time. Patch includes the "Tap on the picture connects the tablet to a computer YUSB." Sorry for mistake.Firmware reuploaded.
If I decompress your file and replace the gps.conf for my area thereafter re-compress it into a zip and transfer it to my SD card before flashing my tablet - would any issues arise?
ChangeLog:
1 Dalvik Cache
2 System
3 Cache
4 Data
5 Android Secure
Successful upgrade!
ChangeLog:
1 Dalvik Cache
2 System
3 Cache
4 Data
5 Android Secure
Successful upgrade!
Thanx for everything lepi!
Can we choose app storage partition size with this custom rom?
There are currently 5212 users online. 2 members and 5210 guests.
