TVLAUNCHER PRO [UPDATED v1.45!!!!] - Hide statusbar and hide apps
    I think we don't need status bar at all
    I have an idea for your laucher
    can you kill status bar for default and add the icons which we use on the status bar to your launcher at the bottom side, so we will have the functionality and we will not need the statur bar
      New version:
      Changes:
      [New] Application now has built in 17 Wallpapers
      [Added] More images in large favorites (36 in total)
      New freaktab version on saturday. Will try to have weather included on the main screen
        Re: TVLAUNCHER PRO [UPDATED v1.07] - Hide statusbar and hide apps
        Hi i would like to say neat app. i bought it to help support!
        just wanted to ask if u can add an icon for an app called PPTV.
        Sent from my Nexus 7
          I'll add it later today Just for you! Thank you for supporting
            Added PPTV icon image. Should be an update in Play store shortly
              Thanks alot!... but too bad atm im getting playstore RPC:AEC:0 =(
                "thanks. deleting and re installing my goggle account worked"
                Seems like that helped for someone
                  Didnt work..
                  Solved it by just installing it from the pc. =)
                  Now just waiting for the latest update with my icon to land.
                  Also sometimes when u change the background, as soon as u press hide bar it goes back to the green leaf one. (while typing this reply, the background suddenly turned black) 2am here so too tired to try to reproduce it but Im using a MK808 stick.
                    Didnt work..
                    Yes, I know. As I stated above: "It works like the other hide bar applications, if you hide the bar, you kill the systemui process. Thats why wallpaper disappears and some other buttons don't work. What I do is simply hide the status bar, then show it again. It will not show unless you change input device. It's kind of a workaround."
                    So just hide the bar, then click it til your wallpaper comes back. Should come when you click it again, but you might have to click it a few more times..
                    Hope that helps!
                      My bad must of skimed through the thread. Im not bothered by it just thought u might like to know =p how much longer til the update shows on playstore u think?
                        Be prepared for this weekend
                        v1.2
                        Huge update coming up!
                          Okay, so here is some of the new features
                          6 Big icons on the main page:
                          With the edit button (top right) you can change icon images and application, so you don't need to go to setting ever time. (You can also long click on the images to get the option):
                          Removed the application bar in the middle, and placed it alone. You can hide apps from here as well
                          You can either click on the apps button (bottom right) or home button (top left), to go between views, swipe or with arrow keys:
                          Hope you are as excited as I am
                            The new version is amazing!
                            Congratulations!
                              Excellent update. Definlty the nrw menu its much better than before
                              Sent from my GT-I9100 using Tapatalk 2
                                Is this on the market?
