TVLAUNCHER PRO [UPDATED v1.45!!!!] - Hide statusbar and hide apps
    Dubble post. Sorry!
      Originally posted by samyboy89 View Post
      That would be great if you could check. If it only occurs on TVLauncher, I'll have to fix it Thanks for reporting.
      Its not your launcher. I get the same thing with ADW and Nexus Launcher. Wont remember which one I chose after reboot.
        Re: TVLAUNCHER PRO [UPDATED v1.2] - Hide statusbar and hide apps
        Stock launchers that come with MK808 still work. I havnt tried with other launchers.
        Sent from my Nexus 7
          Sv: TVLAUNCHER PRO [UPDATED v1.2] - Hide statusbar and hide apps
          So maybe its the rom and not the launcher that has issues? You had the same problem also on finless 1.5a?
          Skickat från min HTC Desire via Tapatalk 2
            The older version you sent me worked for a few hours, since i always leave my device on the next time i went back to it it stopped working as well. Im thinking its some power saving feature thats causing the problem?? as I start the launcher it goes to a black screen then the tv dims. Like if you havnt touched the display of your phone/tablet for a while before the screen turns off.
            *edit - also on finless 1.5a
              Another nice feature would be to be able to ad text in or under the six main boxes. Either just text in a blank box or text on top of a background image for the box. This would be handy if you want to ad an app which doesn´t have any prefab images or you don´t have a fitting image to choose from when that feature is ready.
                TVLauncher v1.35
                14. November
                [New] ★ Choose icons from gallery
                [New] ★ Volume ★
                [Change] ★ Hidebar icon animation ★
                [Change] ★ Apps button moved ★
                [Fix] Bug fixes
                I just sent the update to play store. Give it a few hours and it should come an update for you!
                  Everything seems to be working again =)
                    hi,
                    i don't find how to set transparency on icons
                    thanks for your work
                      @TheBus: Click on the edit button (pencil), then change the transparency with the seekbar above favorites, then finish with clicking the edit button again to complete.
                        Thank you
                        This is a wonderful Launcher!
                        Remember what should be remembered, and forget what should be forgotten. Alter what is changeable, and accept what is mutable.
                          Sv: TVLAUNCHER PRO [UPDATED v1.35] - Hide statusbar and hide apps
                          Is it possible to add a browser bookmark as one of the six big buttons? I regularly use a website with streaming media and it would be really nice to have a shortcut to this site on one button.
                            TVLauncher v1.4
                            16. November
                            [New] ★ Search
                            - Click on the search icon or type anything on your keyboard to bring up the search field.
                            [New] ★ About section in settings ★
                            - See what version your on
                            [New] ★ ActionBar Icons show/hide in setting ★
                            - In Themes section
                            [Fix] Weather fix
                            - Bug - If you were not connected to the internet the app would crash - FIXED
                            - Auto refresh also improved/fixed
                            [Fix] Bugs and stability fixes
                            More goodies coming soon
                            Stay tuned!
                              Re: TVLAUNCHER PRO [UPDATED v1.4!!!!] - Hide statusbar and hide apps
                              Awesome
                              Sent from my GT-I9100 using Tapatalk 2
                                Sv: TVLAUNCHER PRO [UPDATED v1.4!!!!] - Hide statusbar and hide apps
                                Sweet!
