Tried several times, but get message that file is corrupt, also in 7zip. Zipped file size is 1,2 GB?
HPH RK3288 Dual-Boot ROM v1.3 by mo123
Originally posted by benniebob View Post
Tried several times, but get message that file is corrupt, also in 7zip. Zipped file size is 1,2 GB?HTC Wildfire, Samsung s3, Ulefone U7, Doogee DG550
HPH Nagrace 4GB, 32G ROM, CX W8 Wintel Intel Atom Z3735F
Chuwi V88 RK3188, FNF ifive x2, advent vega pov
Creative zen x-fi2
Originally posted by Gormar View PostCan someone tell which DDR memory and GPU frequences this firmware use? You can check that in
Terminal Emulator by executing these commands:
Code:dmseg|grep -i ddrfreq dmseg|grep -i mali_dvfs
456mhz when normal, 528mhz highest for ddrfreq
198,297,313,480mhz for mali_dvfs
1.8Ghz for CPULast edited by mo123; 21 December 2014, 17:03.
Originally posted by benniebob View PostTried several times, but get message that file is corrupt, also in 7zip. Zipped file size is 1,2 GB?
Other users are using the ROM, so it wasn't uploaded incorrectly.
Try to use a different download manager or only download with 1 segment instead of multiple parts.
Anti-virus programs might also mess up the download 7z file before it's completely downloaded but less than 1% chance.
Originally posted by gffmac View PostWill this work on the Tronsmart Orion? Thanks
Sent from my HTC One using Tapatalk
If not working you can flash your stock resource.img & kernel.img afterwards.
(Can get it by unpacking the stock ROM with the flash tool in the second tab)
Originally posted by mo123 View Post456mhz when normal, 528mhz highest for ddrfreq
1.8Ghz for CPU
I currently use Wasser's ROM and I have DDR set to 600MHz when normal and GPU to 594MHz max. And Leolas use even faster settings for memory 642MHz. Speed up is noticable.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Originally posted by Gormar View PostWill you prepare some resource.img with DTB which will have higher clocks for memory and GPU?
Originally posted by Shadi86 View PostProcessed Android.process.media are stopped'' I get this error message when I have boot to Android
Can flash it afterwards also.
Also try flashing boot.img(updated one), kernel, misc & recovery again to wipe data and cache partition from previous ROM. Not necessary to include all those images but I prefer it.
When ROM is fully working, you can flash back the boot_linux.img to recovery to use Lubuntu with the Reboot app. Unfortunately TWRP Recovery doesn't work with a single flash and still have problems on RK3288 devices. Still have to manually flash boot_linux.img.
Wanted to integrate reboot to Recovery/Lubuntu in the shutdown menu but it's too much work and complicated, maybe in the next ROM. Just read up on it in xda forum to see all the steps involved.
Nand partition will show nothing in Android Storage as all the space is now used for userdata partition, should be like that.
Originally posted by m1pnk View Posthow long is being patient.... black screen for what seems ages now ?
Should show bootanimation and then about 3-5 minutes black screen.
Needs to format the partitions and install the apps.
Will then boot to Android desktop.
Second boot should be normal, 15-20 seconds.
Hi mo123 everything works great now thanks, I wondering why the usb hub near hdmi in not work for my remote Melef10 deluxe I must use the other near hdmi out for work, in the stock rom it work good I like the usb near hdmi in for it works fine slide and fast any suggestions?
And how let hdmi cec work any setting in option I have missed?Last edited by Shadi86; 21 December 2014, 19:54.
There are currently 1970 users online. 1 members and 1969 guests.
