HPH RK3288 Dual-Boot ROM v1.3 by mo123
Originally posted by ICU View Post. I flashed Leolas OC'ed resource.img onto Wasser's ROM with similar outcome.
RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Originally posted by Ava View PostHi mo123, thanks for you work. I found few issues, in your first post written what you use lubuntu 14.10 img, but in firmware you use Xubuntu img. Also i tried played some video from youku.com, but firefox write what i need install flash plugin. I got the impression that you use wrong Linux image in your firmware.
Will change to Xubuntu.
Changed default Youtube video playback to HTML5 instead of flash.
Didn't test other sites. Sometimes I make additional changes to my system after I finish firmware and can't always remember if it's included in the ROM I made.
I will also test Opera browser since it based on Chrome source and might work better and faster with flash.
Hopefully Rockchip can fix GPU/VPU playback on Linux and everyone with RK3288 devices can have a much better experience.
thats why i flashed kernal and resource cause i know they are tied together. i only flashed resource becauuse mo123 suggested it. Now I report back to him my findings.
Originally posted by Gormar View PostResource file is quite strongly connected with kernel file. Rather opposite how it should be. I flashed Leolas OC'ed resource.img onto Wasser's ROM with similar outcome.
The funniest thing about this particular signature of mine is that by the time you realize it doesn't say anything it's to late to stop reading it
how can you flash this rom ? tomorrow i get my hph v6 but i don't know how to flash?!? i only know how i can flash my chinese mobile phone with SP Flash Tools =)
do you have a step by step instruction ?
do i have to install some drivers ? i load the ROM, the other boot image and 7zip to unpack the rom...
and now ? maybe u can help me?!?
regards smuji
@Smuji. There you will find comprehensive guide how to upload new firmware.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Originally posted by mo123 View PostTry only flashing resource.img and see if the remote works.
For people that want to add different remote buttons:
There is an Android app, keytest.apk that can get the key scan codes of remotes.
Then you can add those key codes to the generic.kl remote file or create a new file in system/usr/keylayout
http://anguschen.myasustor.com:8080/wordpress/?p=4
Cheers,
-SB---------------------------------------
Currently using U-BOX R89 with mo123 v1.6.
Other android tv device - ADT-1 running latest PureNexus 6.0.1 MM and very impressed with the changes vs stock molly!
Pipo M9S -- CrewRKTab custom rooted 4.4.2
RCA Viking Pro 10 -- Custom stock rooted 5.1 by me <- FOR SALE
----------- ROM by me, the first way to update ZTE Force 4G from ICS to JB http://androidforums.com/threads/fin...om-ics.886408/
Originally posted by ICU View PostI flashed just beelink resource.img and the system would not boot
Is your beelink source 110K4? Is it Ubox(beelink) or beelink?
Cheers,
Originally posted by sawbones999 View PostIs this a file that already exists and can I just copy it from the original 110K4 tronsmart ROM? Also, if I unpack the original ROM(already done) do I need to use ext4 viewer or something to view the contents of system image?
Cheers,
-SB
Beelink r89 PCB v.3 110k4
Originally posted by sawbones999 View PostThat's odd. Do you know which version pcb you have? With 1.2 ROM and updated kernel mo posted on page 13 or around in there(which I think might be this kernel, correct me if I'm way off here mo), I flashed original 110K4 boot image, resource image, and misc image from original tronsmart r28 ROM and got IR working. I'm thinking I only needed resource image.
Cheers,
-SBThe funniest thing about this particular signature of mine is that by the time you realize it doesn't say anything it's to late to stop reading it
Hi Mo
I flashed your rom on a firefly, the boot process is ok but usb ports dont seems to be activated.
If i plug an optical mouse i dont have light on the sensor.
Pacopad
Originally posted by mo123 View PostYes
But not sure about Firefly board, maybe boot.img is also needed, but stock one won't boot.
Maybe upload your boot.img from Firefly then I can look if there are any drivers etc. in there needed to boot properly. Will then make a new boot.img for Firefly board if it's needed.
Pacopad
There are currently 1959 users online. 1 members and 1958 guests.
