I do not own one of these tablets, so let someone experienced with flashing custom ROM's try this and post here their results from testing before trying as a beginner.
I've only changed the boot.img and system.img files...so the rest of the firmware is completely stock. I had errors getting the scatter file to load in the flash tool that was included with the firmware, so I've switched to the version of the SP flash tool I've been using on all of my other ROM's. I had no trouble making a custom CWM Recovery for this ROM with MTK Droid Tools.
This ROM is:
Rooted with ClockworkMod Superuser
Debloated
Init.d/Busybox support added
There were no ABN files, so I'm not sure how to change the user app space on this ROM. It may be combined with the internal SD space.
New boot animation
CWM Recovery created with MTK Droid Tools v2.5.3
Reboot app by Petrus
Google Play Store fixes
English Default
Just follow the instructions in the First Time User's Guide PDF file in the root folder of the ROM kit.
Download
Edit:
Here is RileyROM v1.2 based on factory firmware 1.09.
Download
There are a few differences here. First, you will find both TWRP and CWM recovery options. TWRP was furnished from a link later on this thread...I don't know the source, but there are reports of it working. I attempted to create a CWM Recovery with MTK Droid Tools...it isn't tested, but you can try it if you want.
Next, there is an alternative boot.img file you can use if you want to swap the internal and external SD's. Just flash the swap_sd_boot.img instead of boot.img if you want this option implemented on your tablet.
There are no EBR files with this ROM, so I'm not sure how, if necessary, to increase the user app space. It could be that the ROM is configured to combine userdata with the user partitions....so you may not want to swap internal and external SD if that's the case.
PLEASE READ POST #4 on this thread for information about backing up your IMEI and NVRAM data:
