Teclast T98 4G RileyROM 1.0
    I'm leaving it up to you guys to point out firmware updates for me. So if there is a new one, I can easily put together a new ROM.
    If anyone can capture the OTA update.zip file and provide me a link, I might be able to incorporate the files from it in a new ROM....but I really HATE dealing with OTA updates.
    Do you think that it would be able to update to v1.10 from a "maybe" version of yours based on v1.09?..I was thinking, that if I change the recovery back to the original , perhaps it works...
      The problem with OTA updates is that it undoes all of the changes I make in the ROM by replacing system.img files and boot.img files.
      The best bet would be for someone to install the stock firmware v1.09 and let it update to v1.10.
      Then provide me with a ROM dump using MTK Droid Tools. You can actually do this from CWM or TWRP Recovery without being rooted.
      Randy
        v1.2 is available with stock firmware v1.09.
        See post #1
        [I will update that post as soon as the upload has finished]
        Randy
          If someone feels brave and wants to go through this process...here is a way to get a copy of v1.10 for me to make a v1.3 RileyROM.
          First, flash stock firmware v1.09 from the above link. Let the OTA update install to make your installed firmware v1.10.
          Once you have v1.10 installed, flash either TWRP or CWM Recovery to the tablet by itself...from the RileyROM 1.2 kit.
          Run the MTKDroidTools (included in the ROM kit).
          Reboot the tablet to custom recovery and connect the USB.
          Use the MTKDroidTools to make a backup of the whole firmware on your tablet.
          Zip all of the files (except the userdata.img) to a file and upload it to Mega or Google Drive and provide me a link (you can PM me if you want).
          Good Luck!!!!!!
          Randy
            Hello All,
            I know my query is out of the context of this discussion, but want some solution ?
            I have TECLAST T98. Tab works fine, but i have one query, whenever i install any app from the play store, it gets installed in a Internal Memory which is only of 2GB & not in the Internal Storage of 32GB. I have also inserted a memory card of 16GB & have set my default installation path to SD Card, but still no change.
            As a result, now that internal memory of 2GB is getting full & i can not update or install any more apps from the play store. Please help me.
              As I stated in post #1, there weren't any EBR1 or EBR2 files in the stock firmware, so I was unable to create new ones to increase user app space. It appears that Teclast has limited the app space to 2gb.
              If someone can provide me a ROM dump and send the EBR1 and EBR2 files to me, I can increase the user app space. If they are present, they should show up in an MTK Droid Tools backup.
              Randy
                you haven't seen this http://freaktab.com/forum/mtk-based-...tem-enlargment more simple than EBR
                  It would be more simple, if I actually had the tablet to test any modifications.
                  Randy
                    I've used it and works no instability after one day of use
                      If you have successfully modified the scatter file you can post it here for others to use.
                      Randy
                        I've posted it look at http://freaktab.com/forum/mtk-based-...666#post496666
                        or http://freaktab.com/forum/mtk-based-...tem-enlargment
                        ciao
                          I'm going to receive a T98 32GB in a few minutes...
                          Does the ROM from this thread also work for the 32GB version "C6R3"? If not, is there a RileyROM available for this version and where could we get it from?
                          Thank you!
                            http://www.freak-tab.de/rrileypm/mtk...leyROM_1.1.zip this version was made by Riley and is based on original teclast 1.01 firmware for C6r3 however boot.img and twrp recovery are not working you can use
                            https://mega.co.nz/#!gRAhRYCb!QPhuss...RRXGKH574BC_WE TWRP made by Hanuma50 from 4pda.ru
                            and probably original boot.img from teclast 1.0.1 for c6r3 (and so your tablet is not ROOT)
                            or you can ask to Riley to made one new ROM for 1.0.3 here http://freaktab.com/forum/mtk-based-...k-tablet-rom-s
                            REMEMBER T98 16GB C6R2 and T98 32GB C6R3 have different firmware... at the moment I don't know why
                              Hello guys.
                              I tried to update a firmware on teclast t98 but accidently i flashed it with the firnware version for C6R2 though my tablet is C6R3. the saddest thing is that i can not turn on my tablest now. I tried to flash it with the right firmware but got the error (see the attachment). I would greatly appriciate if you could help me to make the tablet work again, cause now it looks more like a brick.
                                Which version of sp flash tool? Are you sure your tablet is power down?
                                If it's recognized as something also for few second from your pc windows version you can try format+download mode in sp flash tool but you loose surely imei of your tablet if you haven't made a full backup with twrp
                                Need some answer!
