Teclast T98 4G RileyROM 1.0
in device manager of windows do you see "MediaTek PreLoader USB VCOM Port (COMn) "?
i tell you about power off because some time ago i thinked to had power off my tablet dark screen no connection but really it was not poweroff
try to poweron and after press looong loong power button until vibration
then try to connect to PC and look in device manager
Tablets are different than phones, because you can't remove the battery. A bit of trial and error is in order to find the best way to flash your tablet.
The best way I have experienced is to turn the tablet off and unplug it from USB. After you press the download button on SP Flash Tool, connect the USB. Usually the flash will begin.
Otherwise, if you have the USB plugged in with the tablet off, it will go into the charging mode and display the animation for charging the battery. The flash won't go through in that mode.Randy
Hello guys!
Randy i have this greathfull tablet but (c6R3), i scattered with 4G user space , rooted , working TWRP and Randy's 1.1 rom, i have only 1 problem, init.d support cannot get working? There is some scripts but no one is running at boot. Has somone this issue or this is unique for me?
Thanks!
There are currently 2145 users online. 2 members and 2143 guests.
