Your system will automatically reboot after flashing.
UG802 Finless ROM 1.6 "custom" JellyBean - Made from MK802-3
For anyone who couldnt boot into flash mode, i share you a easier approach.
1. Run Bob's PC flash progran
2. Connect ug802. When boot up, install any Reboot App for Root (eg Ligus Tools). Then choose Reboot to bootloader
3. Once you see "Found RK USB mode" on Bob's program, click "Flash" imedately to start flashing
Guys at the bottom of the tool. If it says MASS Storage you are NOT in flash mode.
If is says rock loader USB you are in flash mode, you can then click the flash button. My istructions say this properly. You need to pay attention to what the toolk says at the bottom.
flashing problems my cure
if anyone is have flashing problem IE problems getting the flash tool working like i did at 1st
my cure was to do a factory default on device before flashing
Originally posted by dimkin View PostSwitched to flash mode with RKBatchTool 1.5
After this, with common tools flashed ok
Originally posted by Daved View PostWiFi isn't working well for me... "getting ip address" very often and when it finally connects, it stays connected for 5-10 seconds and then it re-starts connecting again.
Have you opened the case and tried the manual antenna fix?
Or is this problem only with this new Rom?
Originally posted by userx View PostThat's a first report of this... my wifi is full bars.
It happened with this new ROM only.
Originally posted by Runner68 View PostHow can we make the external sdcard read as internal sdcard? I got more then 2gb of application data need to read from the internal sdcard.
Or solder on a 16GB internal chip.... ..... just kidding.
Or use an app move to SD card...
Hope that helps, but most of us use an external SD to get extra storage.
There are currently 2332 users online. 6 members and 2326 guests.
