UG802 Finless ROM 1.6 "custom" JellyBean - Made from MK802-3
Originally posted by Runner68 View Postbut the system only read data from the internal sdcard. The ext sdcard only for storage. The App2sd only move from ram to internal sdcard.
Maybe Bob can help. I think the program thinks the internal SD is the external SD.
You might have to go into root explorer and manually move them.
That would suck but would work.
you can always try to download DirectoryBind
TUTO:http://forum.xda-developers.com/show....php?t=1410262
Originally posted by userx View PostI have a feeling the 1080p is bogus. Manufacture false advertising.
No stock Rom has provided true 1080p with any dongle.
This effects all units with any firmware as sold to us with the stock firmware.
I honestly think the manufactures can't support this feature. Its a lie.
In all other models framebuffer memory size enough only for 1360x768 (UG_fixer_JB can switch to this native resolution, not 1024x768 and not 1280x720).
Now I'm tryng to compile compatible with UG802 JB kernel to extend FB memory size, after it will be done,
native 1920x1080P will be available.
Unable to install recommended Drivers
Tried several PCs and one Laptop, all Systems running WinXP(German). An unknown Hardware is found, but i try to install the Driver i got the Message "the specified location does not contain any Hardwareinformation"
What shall i do ? even the System-Control doen't let me install the Driver
[EDIT] mistake found !! device had usb-debugging enabledLast edited by froen0815; 11-05-2012, 08:08.
i have 2 ug802 finless bob 1.4a even boot loader mode still cant install drivers in 64bit comp or 32 bit comp same error unknown device and wont except finless drivers said not correct drives for device? i made sure to turn off usb debugging an i switched back and forth mass and mnt finless pro doesn't detect even tried reboot to boot loader some one suggested in this thread!Minix neo x7 custom quickshot V3.1 kitkat with cpu1700 video stock and oc ram 720 kernal
HTC Amaze 4g unofficial cyanogen mod 11 KitKat 4.4.4
ASUS Nexus 7 (original 2012 tegra 3) Cyanogen mod 12 Lollipop 5.0.2
Originally posted by 2dark4u View PostNo it's not true. I have maded mod for Allwinner A10 MK802 to enable true 1080P.
There are currently 2343 users online. 10 members and 2333 guests.
