$100 Rikomagic MK12 Amlogic S812 with 2GB/16GB, GLan ...
    Just to let you know, I managed to install OpenELEC on the MK12! I used the S82Plus version found here: http://amlinux.ru/image/6.0.0/
    Everything worked, but...
    1. The IR remote didn't. And the box doesn't have a power button...
    2. More importantly (for me at least) some Kodi add-ons didn't work (Plexus, for instance).
    No luck so far with Android roms: I tried the latest official firmware for the Tronsmart MXIII Plus (USB) and another one from Beelink (?) (SD) and in both cases, after the installation, the box hung on boot.
    I have to say, it was easier than I thought and I didn't manage to brick it!
    So, I'm back to square one: official firmware from July, problems with Kodi 15.2 and the MK12 turning on for no reason...
      Tried this one - stock rom from MXIII Pro 4.4.2 (as it seems that this is what MK12 is)
      Ya tenéis disponible para descargar el ultimo Firmware oficial datado con fecha 16-10-2015 para el TV-Box Android MXIII PRO. Un dispositivo que podemos encontrar con diferentes nombres en le mercado (CX-S819,...) y que monta el SoC Quad Core de Amlogic S812 con 2GB de Ram, 8GB de memoria de almacenamiento eMMc y Wifi de Doble banda. De momento no disponemos de
      Works but still it looks very similar to MK12 stock rom with only difference that remote is not working and notifications in android cannot be read.
      wifi and miracast are not working with it either.
      Are there any Lollipop roms compatible with MXIII Pro ?
        kinda expensive for a S812 TV Box now, and it runs the old Android 4.4, you may try S905 TV box, which supports a resolution up to 4K 60fps,
