DOVLESS - 1.09
USE BLUE DOWNLOAD BUTTON
BUG IN ALL MY PREVIOUS RELEASES (UNTIL 21.01.2015)
IMG ARE NOT SUITABLE FOR "STARTUP MODE"
PHOENIXCARD CRASHES WHEN USING THIS MODE WITH MY PREVIOUS RELEASES
TO FIX YOUR IMAGE IN 3 STEPS:
1) drag, "draco_aw80_dovless_1.09.img" on "imgRePacker.exe".
2) delete ROM draco_aw80_dovless_1.09.img.
3) drop your folder "draco_aw80_dovless_1.09.img.dump" on "imgRePacker.exe".
http://www.freaktab.com/showthread.p...l=1#post273578
If problems with your SDCARD, format it using - "HP USB Disk Storage Format Tool 2.2.3" (free tool, google it), then try again.
BACKUP/RESTORE SCRIPTS:
backup_restore_scripts.zip
TIPS FOR ADDED BENEFITS:
Get Rom Toolbox (lite / free version is sufficient)
and then, via "CPU" button set:
* IO Scheduler:noop
* governor:performance
Also change , via "SD Booster"
SD Card cache size to 2048 kb
apply all of these and set also to "apply on boot"
==> now also in "tronsmart" flavor:
http://www.freaktab.com/showthread.p...s-ROM-1-0-BETA
Previous releases
- 1.08
- 1.07
- 1.05
www.file-upload.net/download-10127974/draco_aw80_dovless_1.05.7z.html
- 1.02
A ROM modification based on:
Finless-ROM-1-1-BETA2
* FULL Credits & Kudos should go to "Bob aka Finless" for his work, the ROM & his continuous contributions and involvement
* If you like this work, please donate to Bob! @ https://www.paypal.com/cgi-bin/websc...=3GN5JFZXXQLCA
* Original ROM discussion thread:
http://www.freaktab.com/showthread.p...-ROM-1-1-BETA2
Furthermore, the team @ 4pda forum is working really hard with tests and research to compensate Allwinner/tronsmart lack of support.
.gif)
A special, big, and deserved thank you ! to them for their work
and particularly in regards to build.prop / CPU / powervr.ini / sdcard and much more
.gif)
* buhsoft2006
* kuzzman
* k100Pipo
NOTES & DISCLAIMER:
* This ROM was made for testing and educational purposes.
* It is not intended for commercial use.
* Software included may be subject to copyright.
* Flash this ROM at your own risk. Developer is not responsible for what you do on your device.
1) For taking advantage of some of the features added to this ROM you will need a USB key.
2) Please consults "installation" portion of this document to resolve issues encountered
All tests are performed on:
Maxone CX-X8 4GB/32GB model
http://www.geekbuying.com/item/Maxon...0M-339872.html
DOVLESS-1.09 ROM : Information and features
This rom contains the following modifications applied to Finless ROM 1.1 - BETA2:
1) OVERCLOCK:
[ATTACH=CONFIG]9723[/ATTACH][ATTACH=CONFIG]9722[/ATTACH][ATTACH=CONFIG]9735[/ATTACH]
Please see dedicated section for changed content.
Please see dedicated section for added content.
Please see dedicated section for changed and added content.
See below link for more details
http://forum.xda-developers.com/show....php?t=1916098
-Changed bootlogo to neutral/anonymous img (I was mad/sad when users like my parents were cursing a this "Finless" box, cause Finless only made it better!)
-INVERTED: BOTTOM NAVIGATION BAR RE-ENABLED
USE ROM TOOLBOX TO DISABLE:
qemu.hw.mainkeys = 0 ==> SET TO 1 TO REMOVE BAR
-Changed bootanimation to minimalist looping google gears ==> animation is disabled by default
USE ROM TOOLBOX TO ENABLE :
debug.sf.nobootanimation=1 ==> SET TO 0 TO ENABLE ANIMATION
-*Tried to add a boot.wav imported from ubuntu's boot sound (ubuntu7) ==> not working at the moment
Changelog
1.09 - thx forum users @ 4pda.ru - updated build.prop with latest suggested tweaks - updated powervr.ini - [URL="http://www.google.com/url?q=http%3A%2F%2Fwww.freaktab.com%2Fshowthread.php%3F21694-ROM-DOVLESS-1-08-%252817-01-2015%2529-based-on-Finless-ROM-1-1-BETA2%26p%3D272502%26viewfull%3D1%23post272502&sa=D&sntz=1&usg=AFQjCNEUOrgsxpXZHUWMXqSK_gRYMdWPNg"]http://www.freaktab.com/showthread.php?21694-ROM-DOVLESS-1-08-%2817-01-2015%29-based-on-Finless-ROM-1-1-BETA2&p=272502&viewfull=1#post272502[/URL] 1.08 - updated build.prop with latest suggested tweaks - updated powervr.ini - PhoenixCard fix for startup mode not working 1.07 - reverted hosts file - tweaked build.prop further 1.05 - build.prop edits and preinstall script modification to remove need for USB, while keeping 1.02 features - REMOVED NEED FOR USB KEY, NOW OPTIONAL - NO MORE HIRITSU BS - UPDATED BUILDPROP WITH "LATEST" suggested changes 1.02 - initial release
