Pipo P9 RileyROM 1.9
    This RileyROM is based on official Pipo firmware dated 12/18/14 with kernel #214. It contains cumulative fixes to some little things...but mainly has compatibility with some more external SD cards.
    I did add some permission fixes to prevent reported problems saving to both internal/external SD that I previously was aware existed. I sure haven't experienced it on my P9.
    This ROM is:
    Rooted with Koush Superuser
    Debloated
    English as default language
    init.d/busybox support added
    Google Play Store fixes
    TWRP Recovery included as an option (thanks Abdul_pt)
    2, 4, 6, 8, 10 or 12gb user app space options (select the parameter file of choice)
    Updated First Time User's Guide
    Multi-User support added
    Reboot App by Petrus
    Wifi version has some more aggressive battery saving features (eliminating 3G services)
    Auto Install apps from external autoinstall folder
    Download 3G Version
    Download WIFI Version (This has some more aggressive build.prop tweaks for battery savings)
    I hope you enjoy this ROM. Please consider a donation to support future RileyROM development.
    Randy
    Thanks randy! Will flash it tomorrow...
    PROUD owner of PiPO M9 Pro
    PiPO P9 best tablet ever owned!!!
    PiPO Tablet Freak and Flashaholic!
      What about wifi wakeup issue?
      Official ROM from 18/12 had it.
        I haven't experienced it on mine. Wifi is on every time it wakes up.
        Randy
          Well then... Time to flash again...
            on Pipo.cn there is a chinese software dated 15Jan2015.
              It comes from the future!
                7 jan 2015
                  Deleted
                    Have someone flashed it?
                    I've selected Wifi on only when charging and still with the wifi wakeup issue.
                      My P9 since I got it does not suffer from this wifi wakeup issue. Neither stock rom or RR1.8 has this problem on my tab
                      Sent from my P9 using Tapatalk
                        What option do you have selected on Wifi on sleep?
                        Never?
                        Only when charging?
                          Never?
                          Only when charging?
                          I leave it on Always
                            That's the reason.
                            When Always selected, wifi won't turn off.
                            When Only when charging or never selected, wifi won't wake up after going to deep sleep.
                            This ROM have same issue.
                              I don't know if that's a good or bad thing, but I can't charge The P9 while it's turned off. Every time I connect the device to the charger or to my PC (via USB Cable), it instantly turns on. The same thing happens when I power off the device while it's connected to the charger or PC. It jusr reboots NOT turns off. Some times I want to charge it while it's turned off because it takes less time to fully charge while turned off.
                              Anyone else having this problem? or it's just a hardware problem with mu device?
