Pipo P9 RileyROM 1.9
I'm not sure which files those are.Randy
Just follow the same procedure you used before...using the flash tool in the ROM kit.Randy
Are you using the same PC you flashed the previous ROM with? If so, something must have changed in the driver setup.
Be sure to use the cable that came with the tablet to flash.Randy
Originally posted by Kenneth View PostI got word that anna ye left pipo....
I've send her a mail with a question about de DRM widevine plug-in we don't have on our Pipo P9 so we can watch live television.
I asked when there was new firmware that have that plug-in.
An this was her answer on 3 april:
Dear Friend,
Good day.
I am afraid we don't have that.
Best regards,
Anna
Your NAND chip is the big one in the middle.
If you turn the tablet so that you read the printed text on the chip right side up, start on the left side of the chip and count up from the bottom.
This may require some trial and error. With the tablet plugged in to the USB hold the power button while shorting the pins. You may need to continue holding the power button during the flash. Sometimes, you can plug in the charger and you can let go of the power button.Randy
There are currently 2162 users online. 2 members and 2160 guests.
