CX-919 (RK3188T & RTL8723BS) problem after flashing - bricked maybe?
Originally posted by budgetgeek View PostRoot, Install "terminal emulator" and type:
su
Then
am display-size 1080x1920
Solved: changed `video.use.overlay=1` to `video.use.overlay=0` in build.prop.Last edited by loboris; 12 February 2015, 12:28.
Originally posted by loboris View PostThank you. I have to use wm size and wm density (it is kitkat rom), but the problem is that the phisycal resolution does not change, so I don't see right and buttom part of the screen if I set wm size 1920x1080
Solved: changed `video.use.overlay=1` to `video.use.overlay=0` in build.prop.Currently Inactive on Freaktab.com
I use: MK903V | MELE F10 Deluxe | Roku 3600R
RIP: MK808b | MK809III | PIPO M9 Pro
There are currently 3441 users online. 2 members and 3439 guests.
