UG802 - broken Micro-USB - soldering Cable to PCB
What kind of Firmware do you have installed yet ?
Did you do Step by Step as written in the Readme ?
Did you disable USB-Debugging ?
Is Storage set to "Mass Storage" and not "MTP" ?
If all set like it should be you will be able to reboot to Flash-Mode, either using the Flash-Tool from your PC or using the Reboot-APP installed on the UG802
Maxxy's red wire connection worked for me!
Originally posted by ivana View Postcan somebody post clear picture from top, not from front where red wire must be connected.
like maxxxy do, but with good connected red wire
thank you
I soldered the wires as per maxxxy's picture apart from the white and green wires which I swapped over (a later post acknowledges they are wrong in the picture). My soldering skills were not good enough to solder them anywhere else. I then had to short the nand pads as I connected to power etc...but could not get Rockchip Batchtools 1.5 to flash driver so tried the 1.6 Finless loader which told me I had a device connected. Erased Nand, flashed 1.6 and success...couldn't have done it without this forum...thanks to all
Originally posted by 123421342 View PostDid you also dremel the case to fit the new wire? Did you solder the shield to ground as well?
There are currently 5668 users online. 1 members and 5667 guests.
