.gif)
UG802 - broken Micro-USB - soldering Cable to PCB
Originally posted by Varno View PostGreat thread!
My Micro-USB port has broken down as well.
I've got a question/idea though, is it not possible to power the device using the normal USB port?
If so, can one not just use a powered USB hub? or would that stop other devices connected to that Hub from being recognized?
Since I'm not qualified to re-solder it myself and have yet to find someone who can, I tried to run the UG802+ another way.
I've bought an Powered USB Hub (which I needed anyways), I also bought a normal USB Male-to-Male cable to connect the UG802+ to the USB hub.
Now the device powers on but non of the other devices I connect to the USB hub are recognized by the UG802+..
Does anyone have any idea why?
Crap, mine finally broke too. The connector did not come off but the pin pads to the board traces did... VERY WEAK connector design if you ask me.
I personally think this is going to be a problem with all micro USB board connectors that are soldered to the board. The connector pins can move in the connector case and in doing so they pull off the solder pads on the board. So it's not the connector breaking off the board completely although that can happen, the pin pads lift the traces off the board!!!! Shitty design but we cant blame Ugoos excpet for deciding to use them. This is probably why other TV devices like MK808 use mini connectors instead of micro connecotrs. Thet are proven and more robust / solid.
I honestly see no way a board maker could solve this. They can't really made the solder pads larger to compensate as there is no room to do so. Ugoos did not design and make these connectors. They are off the self. Maybe there are better ones available?
Bottom line I was able to fix my connector by soldering small wire wrap wires back on the original connector pins and then running those wires to the places on the board shown here in this post. So at least my micro usb connector is there and works again and I can put it back in the case.
My MX1 OTG port I had to fix already too. I got to it before it broke
double crap, mine has broken now
I am intending to go for the option of re-soldering the usb connector, I can do the connector pins, and the 'wings' either side, but am unsure about that 'goldy' coloured pad underneath at the edge of the board. Does anybody know/can tell me what this is and if its important in re-connecting the connector?
Also, I might be mistaken, but I seem to recall, either on this site or another one, some kind of reference to some solder type glues, (or am I going of my head), any help would be appreciated!
Originally posted by Finless View PostCrap, mine finally broke too. The connector did not come off but the pin pads to the board traces did... VERY WEAK connector design if you ask me.
im asking due i saw people invert the order of the white and the green cable.
Originally posted by jimac View Postdo you think it would be worth securing the connection with epoxy resin, to try and prevent damaging it?
The case has been removed before as I did my own wi-fi antennae mod, so will pop-off easily now.
Definitely using the epoxy gun to secure the cables its highly recommended
There are currently 2117 users online. 1 members and 2116 guests.
