Anyone working on firmware for the Eny M8S Amlogic S812 square box?
    Upon further inspection it seems that my M8S has the bcm4335 chipset and it doesn't go into recovery mode at all and build number is: M8S.BCM4335.201510211506
    Kernel version is 3.10.33 ubuntu@google-server #1 Wed Oct 21 10:28:09 CST 2015.
    However, on Aliexpress, under description they stated that the wifi chip was AP6330 however, these boxes all have the newer wifi chip BCM4335, stock rom is not bad other than the auto HDMI not being able to turn off. It does turn off however, the chosen resolution doesn't stick after a reboot or replug, you have to select it again from display settings.
      The chip where the wifi chip usually is, has this written on it: KM3208070 and then XJ-A. Is this the new Broadcom chip? Shouldn't it say 4335? Clone chip?
        not true. i have two of these boxes and neither went into recovery when i first got them, but one now goes into recovery and one does not. i am not sure exactly how i got the one to go into recovery, but i think it has something to do with recovery not being mounted. i even looked in the mount file and the recovery and bootloader are not in there but they do come up in terminal, but they are not mounted. i am 100% sure sure that recovery and bootloader modes work they just need to be properly told where the mount point is.
          mike m8s is ap6330 the m8s+ is 4335
          Bugs are Sons of Glitches!
          JustMe
            Justme can u help please I install the fw for the m8s+ 5.1.1 on my m8s everything work but the remote and the ethernet doesn't work how I can fix I can copy the drives from other fw ?? Please help
              Just got my m8s yesterday the mediabox description says bcm4335 so they must have migrated that wifi chipset to the m8s as well
              Cheers,
              Vec
                Cheers,
                Vec
                I think you probably got the same one I got, however, do open it up an check if the wifi chipset is actually 4335 or is it like mine where the chipset is KM3208070.
                  bonjour,hello
                  Do you have information for Ms8 ? please
                  firmware is dead
                  I look for a firmware
                  tv box transpeed --- ms8
                  original firmware
                  kitkat 4.4.2
                  KOT49H- 20151011 testkeys
                  AP 6330
                  kernel 310.33
                  kc@kc-server#2
                  sun oct 11 14:43:56 cst 2015
                  CS_812M8-V1.2
                  currently firmware KII Acemax
                  kernel 3.10.33 ap6330 wed 22 jul cst 2015
                  Remote control does not work ,
                  my remote has color buttons
                  help me
                  Sorry i'm not speak english
                  i'm french
                  merci
                    do you have your orginal firmware?, i can craete a updater file if you haven't tried this already last links http://freaktab.com/forum/tv-player-...zips#post18312
                    JustMe
                      Hello Mr JustMe, Thank you for the help(assistant)
                      I have no original firmware. My tv box on the firmware acemax at present KII Acemax
                      (kernel 3.10.33 ap6330 wed 22 jul cst 2015)
                      my original firmware erased ( brick led red for update )
                      original firmware
                      kitkat 4.4.2
                      AP 6330
                      kernel 310.33
                      kc@kc-server#2
                      CS_812M8-V1.2
                      Your link------>M8S s812 Remote
                      Download
                      I tried and she(it) does not work for remote control
                      merci
                      Sorry, for my speak English
                      ( traduction google)
                      Thank you very much
                        ok hmm have you tried to ask your seller for firmware due to this issue I mean I can help you by posting few remote configurations but if your seller can supply you with stock rom it would be easier than guessing remote configurations
                        JustMe
                          Merci
                          Good idea !!! I sent an e-mail for the Chinese seller link ---- > ici
                            Originally posted by ra111 View Post
                            but needs a login account to download
                            no it doesn't - use jdownloader and copy the link for the zip file. the link grabber in jdownloader will grab it and start downloading - it's doing it for me as i type
                              good Yes , ça marche !!
                              merci
                                HelloJustMe . I did Brick in M8S. I installed the wrong firmware, and I can not fix it. My dealer gave firmware cyx_m8s_v8.6_bcm4335_8g2g_kodi_addons_151029_SD 升级.rar. After installation of SD-card, these errors occur as in a photograph. Help me please.
                                You may only view thumbnails in this gallery. This gallery has 5 photos.
