Anyone working on firmware for the Eny M8S Amlogic S812 square box?
    As for the Baidu downloads you could try JDownloader ( http://jdownloader.org/ ) Works great with Baidu
      Ethernet only reliable option on M8S :-(
        i tried to install the n200-ota-20150728.zip on my m8s.
        it boots and says mbox, afther that it keeps flashing up the "launcher"
        Can anyone pls help to solve this problem??
        im trying to get my box to work for more then a week now...
          Can anyone please guide me on how to root the stock rom on OTT M8S Adnroid 4.4.2? I am trying to root it from past 2-days, using different 1-click root methods, but all failed. May be it is different for Android TV box.
          Edit: Rooted now.
            I attempted to update the firmware on an M8S box using an SD card, but it froze on the open android screen with the progress bar... Since then the box does not boot at all. I have tried a variety of different firmware versions from the links posted to this thread and several different cards with the toothpick in the av hole but to no avail, the device never initializes the HDMI display so the TV shows no signal.
            Strangely however, the device response to the power button on the remote by changing the front light from blue to red and back again.
            Also having opened the box up, it looks considerably different to the other M8S boxes shown here...
            Any suggestions on what else i could try?
              Have now connected a TTL cable to the pins on the board, and i get:
              Code:
              QA9:A;SVN:74E;POC:37F;STS:0;BOOT:0;INIT:0;READ:0;CHECK:0;PASS:0;
              no sdio debug board detected
              TE : 30013
              BT : 11:30:18 Mar 14 2014
              voltage set from 0x18 to 0x24, addr:0x36
              voltage set from 0x18 to 0x2c, addr:0x37
              voltage set from 0x38 to 0x48, addr:0x38
              voltage set from 0x4e to 0x50, addr:0x4c
              voltage set from 0x24 to 0x24, addr:0x4d
              voltage set from 0x30 to 0x30, addr:0x4e
              voltage set from 0x4e to 0x4e, addr:0x4f
              voltage set from 0x24 to 0x24, addr:0x50
              voltage set from 0x28 to 0x28, addr:0x56
              voltage set from 0x00 to 0x00, addr:0x57
              CPU clock is 792MHz
              Aml log : DDR0 - init pass with
                PGSR0 : 0x80000fff
              Aml log : DDR1 - init pass with
                PGSR0 : 0x80000fff
              DDR clock is 696MHz with 1T mode
              But it never goes any further than this...
              I suspect the hardware has failed?
                Are you able to enter into recovery ?
                  Hi guys, ive just bught one of these s812 boxes (m8s) but now after reading this it seems a mistake. Should i get a refund or are these usable?. I wanted it to replace my firestick and have usb/sd card support.
                    They work but I'm sure there's better supported infact there must be as these have ZERO support, I'm still using mine not overly happy upgraded the remote which has helped ! how much did you pay ?
                      I have an OTT M8S box and initially thought it's crap. horrible remote... I have fixed the remote issue which is just a mechincal flaw, as described in the link. Now I have zero problems!
                      bert64, I also bricked my device once, but was able to create a recovery SD. If you want I can send you the zip with all the files on it. Worth a try i guess... Had to boot with a toothpick in the AV. Can't remember if I had the card in or out when doing tho. But it's either or...
                      So I was digging into my remote problem with the M8S box. I noticed the remote works well when I directly target the blue receiving triangle. But from an angle it's
                        45 pounds with one of those bluetooth keyboards too . i may try and send it back and ge tar efund.
                          What firmware then? do you get the wifi issues people get?
                            I tried wifi and it wokred without problems, tho i am using ethernet in my setup. At the moment no issue at all, running the August orig firmware from Chinagadgets: http://chinagadgetsreviews.com/downl...-tv-box-2.html
                            And with my remote sensor mod, remote also works without a hickup...
                              Do you use the latest kodi? hows it running?. Playstore ok?
                                Can anybody please upload ENY_m8s_ap6330_8g2g_150728_SD_withoutaddons.rar to a filehost for me? I can not seem to register on Baidu...
