Anyone working on firmware for the Eny M8S Amlogic S812 square box?
Looks like m8s, run h265 codec and see if it plays it.Bugs are Sons of Glitches!
JustMe
I received stock image firmware from my M8S support, filename aml_upgrade_package.img . But with instruction how i need flash it via Amlogic Burning Tool. But i don't have usb otg cable. Does it possible to convert this image that it can be flashed from SD card?Last edited by Samovar; 29 May 2015, 22:40.
Does anyone know if there is a difference between http://pan.baidu.com/s/1dD0Ey9V and http://pan.baidu.com/s/1dDdD565 ?
I am using the latter (http://pan.baidu.com/s/1dDdD565) and have noticed some random crashes and issues with the remote. Wondering if worth trying the other one.
btw, how do people that don't read chinese open a baidu account? seems one is mandatory now to download.
Why eny has to post their software on Baidu knowing full well that bigger files require the use of some Chinese downloader program or you going about setting up a cloud account with baidu to get the file... smaller files usually you can get without a account but bigger files are a pain in the butt...
anways... ive had issues with both of those files and I see some of the eny resellers pushing stane's software which is much more stable then eny's stuff
There are currently 2211 users online. 1 members and 2210 guests.
