Cube Talk 9X [U65GT] roms/recoverys/mods etc. list
Originally posted by giouncino View Post
Does USB OTG is working with CM13 too?
Did you test 3G ?
Could you please post the link to download it?
thanks in advance
Did you test 3G ?
thanks in advance
I had as you Lepis ROM, them I moved to Atlantis both were Kitkat based, I wanted to install some apps I use, but they needed Android 5 or more and I was looking for a newer API rom
I had seen this post 1 week ago I made a TWRP backup in my kitkat rom in case something goes wrong I made a factory reset ( I had not erased Internal memory and my external SD ),
I had made all my apps a Final Titanium backup and I had installed it, ( through TWRP )
It is super fast I had not noticed any bugs so far ( 1 week ), I had not a 3G card to test it, but I can confirm that OTG is working fine.
I had restored all my USER apps using Titanium Backup.
It had root access empeded in Developer settings there you can enable or disable it.
I had downloaded Xposed for Android 6.0, it is working fine I cannot live without Xposed due to App settings, Lucky Patcher, and Minmin guard and Gravity box module. Using app settings module you can edit dpi and text and a lot of other things PER APPICATION, some apps had small fonts some very big so with this module you can adjust every app as you like.
So whatever you want any help I can help you HERE ALL ARE WORKING FINE SO FAR, no crashes, no random reboots...
Bye for now
Edit ----- to help you more I moved my 3G data card from my mobile to Cube to test if 3G is working
It is working fine I downloaded apps and tried youtube WORKING FINE. No problem with 3G
The download link is https://yadi.sk/d/W-P6-FRd3GCfAF
Guest
Bye for now
I also searched for an Custom ROM for my U65GT, that bases on Marshmellow/Android 6. Because U65GT ran out of memory after the installation of a few apps.
Finally i found the ROM you linked above. Is it from "smallship"?
And after a few attempts, the installation worked fine, as you discribed.
But i cannot use my SD-Card as internal memory. All my attepts failed with "SD Memory corrupt".
With the help of Google-Translator, i translated nearly every post from "smallship" in 4pda's forum. If i understood right, there is an issue with increasing internal memory as adopted memory, but i did not understand in detail and i found no solution.
Did you manage to adopt memory in U65GT? What do i have to do?
Originally posted by Roger01
Hello leotzian!
I have no problem with both.I flashed this ROM with twrp.
A year ago using splash tool and mbr files I had partioned my 32gb to 16gb as internal memory and 16gb as internal sd memory.
this tab has 2gb as internal memory and you get out of memory very soon.
This was my first step the first day I bought this tab. This has nothing to do with the ROM.
Guest
Originally posted by leotzian View PostHi my tab it's 32gb and I use a external microsd 32gb also.
I thought, I could increase internal memory with this CM13/Android 6-ROM. But i get errors ("SD Card corrupt)".
I would like to avoid playing around with MBR-stuff but it seems, this is my last change to get more memory.
OK, thank you.
Sent from my U65GT using Tapatalk
hello every one
iI purchased a touch screen for my device but almost did not match
I installed it but I had a problem that the touch was reversed ( upside down )
I then contacted the supplier from the aliExpress site and told me to update the firmware and I did so but without merit .
did you have any solution to me? please the device is more important to me..
thank you all
Probably you can calibrate the touchscreen through MTK engineering toolif you appreciate my efforts this is the link for any donation:
I installed CM13 one year ago and still works good...if you appreciate my efforts this is the link for any donation:
There are currently 2836 users online. 0 members and 2836 guests.
