Cube Talk 9X [U65GT] roms/recoverys/mods etc. list
21Mbps is maximum for u65gtif you appreciate my efforts this is the link for any donation:
You asked about download speed, and that is the aswerif you appreciate my efforts this is the link for any donation:
Thanks giouncino, That helps! one question, what is max 4g tabs can reach to and do we get that mbps speed usually using sim?
Q2 . I had also asked a question regarding power charger, so was confused with your answer. What is the best charger we can use for this tab and others in general, 2amp, 3amp, as charging time is too much but on the other hand, I don't want to damage battery or other components. OIn market some 3 amp chargers are coming but then they when you buy they display dual 2 amp + 1 amp ?
2-2.5Amps are more than sufficient: there is an integrated circuit inside the tablet that prevent to go over that.
So a 3Amps charger or more is useless. There is no way to reduce battery charge time for U65GT, you always need almost 7 hours for a complete charge.
U65GT is a 3G only, so you can't go over 21Mbps rated speed.if you appreciate my efforts this is the link for any donation:
Originally posted by giouncino View Post2-2.5Amps are more than sufficient: there is an integrated circuit inside the tablet that prevent to go over that.
Otherwise what about Cube T9 and other 4g tablets, how much can 4g tablets reach to max using the sim slot?
You should ask that on T9 topic.
I have no feedback about REAL download speed on T9if you appreciate my efforts this is the link for any donation:
Originally posted by ADB user View PostOtherwise what about Cube T9 and other 4g tablets, how much can 4g tablets reach to max using the sim slot?
I'm not sure if this is the right thread, but after a system update (something to do with the WIFI I think) my Cube Talk 9x (U65GT32GB15131973J) fails at boot. It goes to the dead droid "no command" screen and then all I can do it access recovery mode via the power button, or the Boot Mode options. It won't connect to the laptop in Uart - The laptop makes the right noises, but the tablet doesn't appear in as an accessible device. I can access the external SD card from Recovery, but it just wants to install an update from there. I'm not sure how to recover, what file I should use to try and update as a recovery, or what other options are open to me. Any help would be gladly received.
Thanks!
you can simply flash the whole ROM again from the PC.
It is not important that you cannot see the device on windowsif you appreciate my efforts this is the link for any donation:
Originally posted by giouncino View Postyou can simply flash the whole ROM again from the PC.
Thanks - Is there a guide for the set of steps to do that? I have tried following: http://freaktab.com/forum/tablet-sup...s-windows-7-64 But I can't do the 'back-up and scatter' stage (The MTK Droid Tool app doesn't see the device) and the SP Flash Tool just seems to hang when I set it off (I downloaded an alternative scatter file, but all the addresses are blank when in SP Flash) - So nothing happens.
I can see the device connected as ADB Android on the PC when I connect in that mode, under devices.
The attached images are the only menu interaction with the tablet that I can get (NB No Install from Zip option) - The tablet can still read the sdcard and sdcard2 when searching to update from there.
Thanks again for the assistance.
The issue is solved - I used 900Supersport's ROM from here: http://freaktab.com/forum/mtk-based-...amp;viewfull=1 and loaded the scatter file. Once the tablet (turned off) was connected, the SP Flash Tool took over and finished the job. The tablet is now functioning again.
Thanks to Giouncino and 900Supersport, and Freaktabs in general.
There are currently 4275 users online. 0 members and 4275 guests.
