Cube Talk 9X [U65GT] roms/recoverys/mods etc. list
    Please I want to make another question.
    As I see rom updates from Lepi are very often, If someone has a lot of user apps and data, meaning to setup all these, needs a lot of time and days perhaps, isn't possibe to update only erasing Dalvik Cache, System and Cache Only?
    Lepi recommends Dalvik Cache, System,Cache,Data, Android Secure ( Data, Android Secure meaning that all user apps data are deleted)
    Am I wrong?
    Thanks in advance
      error with camera (camera can't open )
      hello , i am an owner of cube talk 9x the last 3 days and from the first day i rooted the tablet and i was a little bit disappointed of camera as it has some blur and i couldn't focus as i think. suddenly yesterday i try to reopen the camera and i got the message camera can't open. from then i flashed the latest lepi and the 2 other roms and i got the same message .do you know what should i do ?
        From where did you get the tablet, is a geniune one? is the serial number at the back of the the tablet the Cube format?
        The blur problem was present and before you had rooted it? ( I don't think it is root related )
        I ask you because here are reported alot of times fake ones.
        It might be a hardware problem.
          my format of serial is U65GT16GB15020808J
          bought it from amazon as an item " sold by ***** and Fulfilled by Amazon
          after every flash of rom i see the camera icon for around 10 secs and after is disappeared
            Serial seems ok, I had never heard of such a problem, may be other owners will help you better perhaps Lepi
              Hi did you try any camera apps from the play store to see if they work as it might be a hardware problem as leotzian mentioned.
                yes i have tried 2- 3 apps but nothing happend .. i read all over internet many people with differen devices are saying that is an android prob and some a hw issue but i do not know what is it finally
                  Was this a new tablet you bought as you might have to get them to replace it as if it still under warranty then the manufacturer should fix it..but if you just got this cube I would ask to send it back and get them to replace it if you cannot get the camera to work.
                    i will try to find out what's happening now, and then if i cannot work it out i will contact with amazon as the item was new in order to replace refund .many people have the same issue on nexus 5 but there is no standard solution/fix for this
                      Am I wrong?
                      Thanks in advance
                      Hi..you are not wrong if you clear all those areas as lepi says you will lose your apps and user data.
                        Did the camera work when you first got the cube or was it acting up already when you got the cube.
                          it was working but the resolution wasn't so good i think
                            You mentioned it would not focus in your earlier post..it just might be a hardware problem..I will take a look around and see if I can find any info on this problem.
                              thank you very much for your help! i am seasrching too hoping for something good
                                So what you suggest do not clear data and android secure?
