Cube Talk 9X [U65GT] roms/recoverys/mods etc. list
Originally posted by sobi View Posti cannot even start the app of the camera.
Now just leave the cube load by itself and it will go to a testing screen which will also disable any rooted apps on the cube...here you can test the camera besides other stuff and see if the camera works and also the front camera can be tested also..if the camera opens when you choose camera hit the selection in blue to take a pic and see if it does.
If the camera loads though then it most likely due to an app that has affected the camera or the camera app itself could be corrupt and the camera may not load at all..if the camera loads and taking a picture works, then one of the apps you installed may be affecting the camera not to work and you will have to start uninstalling them one by one to see which one is the culprit, or there is an option which you will see that says factory settings, if you go into there you can wipe all user data and downloaded apps if you would like to do this but you will lose all the stuff you added..do not hit the back button on the bottom of the screen as it will take you out of this testing screen and you will have to do the procedure above all over.
This is up to you if you would like to do this as if you use the factory setting selection and clear it all out you will lose all the stuff you added, if you do not use this option your stuff will still stay in from just testing it..you will just have to give the apps the root permission again afterwards is all and some shortcuts might be missing..but nothing will be lost..hope this helps you out in your situation.
If this does not help you situation..then most likely a hardware problem..but i am not 100% sure on that part yet.
I mean had you deleted any system app from the device. Just a thought..
Originally posted by leotzian View PostSo what you suggest do not clear data and android secure?
Hello.
Owner of a rooted Cube U65gt running stock rom, updated ota with the last official January update.
Fully satisfied with the laptop except for one thing. The lack of multiuser support.
So what I would like to ask is if it possible, using the stock firmware, to enable the "USERS" option in android settings.
Thank you.
Thank you.
22. The patch adds multiplayer mode ( 4 users) for firmware V2.0_20141110 from SLK88
Thanks to the dev SLK88 from 4pda.ru.
The bad thing is that you can't download it unless you register to the site (4pda.ru). Maybe you can ask Lepi or Cherva70 to upload it to somewhere else. If you got it somewhere how about share it here so I can add it to Talk 9X info thead?
Originally posted by cabrinha View PostThank you very much. Tried to register but with no success. They do not even accept gmail as a valid email address...
Just translate captcha code and write only result in box (use only numbers) and will work.
Tried myself a few times until I've realised .
I found it.
Click ---> 22. The patch adds multiplayer mode ( 4 users) for firmware V2.0_20141110 from SLK88
How do I install it?
And something else.
My tablet runs the v2 stock rom. With this rom there is a problem with physical keyboards. For example w key is not working. This happens because there is an error in keyboard mapping. When you press the w key in the keyboard the tablet executes the w gesture and if w gesture is not assigned to anything then the tablet does nothing. In order to fix this problem and make w key working (and of course all the keys that do not work) you have to edit the generic.kl file which is found in the /system/usr/keylayout folder.
This is what my generic.kl contains and works perfect with my sigmatek usb keyboard case.
Code:[LIST][*]# Copyright (C) 2010 The Android Open Source Project [*]# [*]# Licensed under the Apache License, Version 2.0 (the "License"); [*]# you may not use this file except in compliance with the License. [*]# You may obtain a copy of the License at [*]# [*]# http://www.apache.org/licenses/LICENSE-2.0 [*]# [*]# Unless required by applicable law or agreed to in writing, software [*]# distributed under the License is distributed on an "AS IS" BASIS, [*]# WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. [*]# See the License for the specific language governing permissions and [*]# limitations under the License. [*]# [*]# Generic key layout file for full alphabetic US English PC style external keyboards. [*]# [*]# This file is intentionally very generic and is intended to support a broad rang of keyboards. [*]# Do not edit the generic key layout to support a specific keyboard; instead, create [*]# a new key layout file with the required keyboard configuration. [*]# [*]key 1 ESCAPE [*]key 2 1 [*]key 3 2 [*]key 4 3 [*]key 5 4 [*]key 6 5 [*]key 7 6 [*]key 8 7 [*]key 9 8 [*]key 10 9 [*]key 11 0 [*]key 12 MINUS [*]key 13 EQUALS [*]key 14 DEL [*]key 15 TAB [*]key 16 Q [*]key 17 W [*]key 18 E [*]key 19 R [*]key 20 T [*]key 21 Y [*]key 22 U [*]key 23 I [*]key 24 O [*]key 25 P [*]key 26 LEFT_BRACKET [*]key 27 RIGHT_BRACKET [*]key 28 ENTER [*]key 29 CTRL_LEFT [*]key 30 A [*]key 31 S [*]key 32 D [*]key 33 F [*]key 34 G [*]key 35 H [*]key 36 J [*]key 37 K [*]key 38 L [*]key 39 SEMICOLON [*]key 40 APOSTROPHE [*]key 41 GRAVE [*]key 42 SHIFT_LEFT [*]key 43 BACKSLASH [*]key 44 Z [*]key 45 X [*]key 46 C [*]key 47 V [*]key 48 B [*]key 49 N [*]key 50 M [*]key 51 COMMA [*]key 52 PERIOD [*]key 53 SLASH [*]key 54 SHIFT_RIGHT [*]key 55 NUMPAD_MULTIPLY [*]key 56 ALT_LEFT [*]key 57 SPACE [*]key 58 CAPS_LOCK [*]key 59 F1 [*]key 60 F2 [*]key 61 F3 [*]key 62 F4 [*]key 63 F5 [*]key 64 F6 [*]key 65 F7 [*]key 66 F8 [*]key 67 F9 [*]key 68 F10 [*]key 69 NUM_LOCK [*]key 70 SCROLL_LOCK [*]key 71 NUMPAD_7 [*]key 72 NUMPAD_8 [*]key 73 NUMPAD_9 [*]key 74 NUMPAD_SUBTRACT [*]key 75 NUMPAD_4 [*]key 76 NUMPAD_5 [*]key 77 NUMPAD_6 [*]key 78 NUMPAD_ADD [*]key 79 NUMPAD_1 [*]key 80 NUMPAD_2 [*]key 81 NUMPAD_3 [*]key 82 NUMPAD_0 [*]key 83 NUMPAD_DOT [*]# key 84 (undefined) [*]key 85 ZENKAKU_HANKAKU [*]key 86 BACKSLASH [*]key 87 F11 [*]key 88 F12 [*]key 89 RO [*]# key 90 "KEY_KATAKANA" [*]# key 91 "KEY_HIRAGANA" [*]key 92 HENKAN [*]key 93 KATAKANA_HIRAGANA [*]key 94 MUHENKAN [*]key 95 NUMPAD_COMMA [*]key 96 NUMPAD_ENTER [*]key 97 CTRL_RIGHT [*]key 98 NUMPAD_DIVIDE [*]key 99 SYSRQ [*]key 100 ALT_RIGHT [*]# key 101 "KEY_LINEFEED" [*]key 102 MOVE_HOME [*]key 103 DPAD_UP [*]key 104 PAGE_UP [*]key 105 DPAD_LEFT [*]key 106 DPAD_RIGHT [*]key 107 MOVE_END [*]key 108 DPAD_DOWN [*]key 109 PAGE_DOWN [*]key 110 INSERT [*]key 111 FORWARD_DEL [*]# key 112 "KEY_MACRO" [*]key 113 VOLUME_MUTE [*]key 114 VOLUME_DOWN [*]key 115 VOLUME_UP [*]key 116 POWER WAKE [*]key 117 NUMPAD_EQUALS [*]# key 118 "KEY_KPPLUSMINUS" [*]key 119 BREAK [*]# key 120 (undefined) [*]key 121 NUMPAD_COMMA [*]key 122 KANA [*]key 123 EISU [*]key 124 YEN [*]key 125 META_LEFT [*]key 126 META_RIGHT [*]key 127 MENU WAKE_DROPPED [*]key 128 MEDIA_STOP [*]# key 129 "KEY_AGAIN" [*]# key 130 "KEY_PROPS" [*]# key 131 "KEY_UNDO" [*]# key 132 "KEY_FRONT" [*]# key 133 "KEY_COPY" [*]# key 134 "KEY_OPEN" [*]# key 135 "KEY_PASTE" [*]# key 136 "KEY_FIND" [*]# key 137 "KEY_CUT" [*]# key 138 "KEY_HELP" [*]key 139 MENU WAKE_DROPPED [*]key 140 CALCULATOR [*]# key 141 "KEY_SETUP" [*]key 142 POWER WAKE [*]key 143 POWER WAKE [*]# key 144 "KEY_FILE" [*]# key 145 "KEY_SENDFILE" [*]# key 146 "KEY_DELETEFILE" [*]# key 147 "KEY_XFER" [*]# key 148 "KEY_PROG1" [*]# key 149 "KEY_PROG2" [*]key 150 EXPLORER [*]# key 151 "KEY_MSDOS" [*]key 152 POWER WAKE [*]# key 153 "KEY_DIRECTION" [*]# key 154 "KEY_CYCLEWINDOWS" [*]key 155 ENVELOPE [*]key 156 BOOKMARK [*]# key 157 "KEY_COMPUTER" [*]key 158 BACK WAKE_DROPPED [*]key 159 FORWARD [*]key 160 MEDIA_CLOSE [*]key 161 MEDIA_EJECT [*]key 162 MEDIA_EJECT [*]key 163 MEDIA_NEXT [*]key 164 MEDIA_PLAY_PAUSE [*]key 165 MEDIA_PREVIOUS [*]key 166 MEDIA_STOP [*]key 167 MEDIA_RECORD [*]key 168 MEDIA_REWIND [*]key 169 CALL [*]# key 170 "KEY_ISO" [*]key 171 MUSIC [*]key 172 HOME [*]# key 173 "KEY_REFRESH" [*]# key 174 "KEY_EXIT" [*]# key 175 "KEY_MOVE" [*]# key 176 "KEY_EDIT" [*]key 177 PAGE_UP [*]key 178 PAGE_DOWN [*]key 179 NUMPAD_LEFT_PAREN [*]key 180 NUMPAD_RIGHT_PAREN [*]# key 181 "KEY_NEW" [*]# key 182 "KEY_REDO" [*]# key 183 F13 [*]# key 184 F14 [*]# key 185 F15 [*]# key 186 F16 [*]# key 187 F17 [*]# key 188 F18 [*]# key 189 F19 [*]# key 190 F20 [*]# key 191 F21 [*]# key 192 F22 [*]# key 193 F23 [*]# key 194 F24 [*]# key 195 (undefined) [*]# key 196 (undefined) [*]# key 197 (undefined) [*]# key 198 (undefined) [*]# key 199 (undefined) [*]key 200 MEDIA_PLAY [*]key 201 MEDIA_PAUSE [*]# key 202 "KEY_PROG3" [*]# key 203 "KEY_PROG4" [*]# key 204 (undefined) [*]# key 205 "KEY_SUSPEND" [*]# key 206 "KEY_CLOSE" [*]key 207 MEDIA_PLAY [*]key 208 MEDIA_FAST_FORWARD [*]# key 209 "KEY_BASSBOOST" [*]# key 210 "KEY_PRINT" [*]# key 211 "KEY_HP" [*]key 212 CAMERA [*]key 213 MUSIC [*]# key 214 "KEY_QUESTION" [*]key 215 ENVELOPE [*]# key 216 "KEY_CHAT" [*]key 217 SEARCH [*]# key 218 "KEY_CONNECT" [*]# key 219 "KEY_FINANCE" [*]# key 220 "KEY_SPORT" [*]# key 221 "KEY_SHOP" [*]# key 222 "KEY_ALTERASE" [*]# key 223 "KEY_CANCEL" [*]key 224 BRIGHTNESS_DOWN [*]key 225 BRIGHTNESS_UP [*]key 226 HEADSETHOOK [*]key 256 BUTTON_1 [*]key 257 BUTTON_2 [*]key 258 BUTTON_3 [*]key 259 BUTTON_4 [*]key 260 BUTTON_5 [*]key 261 BUTTON_6 [*]key 262 BUTTON_7 [*]key 263 BUTTON_8 [*]key 264 BUTTON_9 [*]key 265 BUTTON_10 [*]key 266 BUTTON_11 [*]key 267 BUTTON_12 [*]key 268 BUTTON_13 [*]key 269 BUTTON_14 [*]key 270 BUTTON_15 [*]key 271 BUTTON_16 [*]key 288 BUTTON_1 [*]key 289 BUTTON_2 [*]key 290 BUTTON_3 [*]key 291 BUTTON_4 [*]key 292 BUTTON_5 [*]key 293 BUTTON_6 [*]key 294 BUTTON_7 [*]key 295 BUTTON_8 [*]key 296 BUTTON_9 [*]key 297 BUTTON_10 [*]key 298 BUTTON_11 [*]key 299 BUTTON_12 [*]key 300 BUTTON_13 [*]key 301 BUTTON_14 [*]key 302 BUTTON_15 [*]key 303 BUTTON_16 [*]key 304 BUTTON_A [*]key 305 BUTTON_B [*]key 306 BUTTON_C [*]key 307 BUTTON_X [*]key 308 BUTTON_Y [*]key 309 BUTTON_Z [*]key 310 BUTTON_L1 [*]key 311 BUTTON_R1 [*]key 312 BUTTON_L2 [*]key 313 BUTTON_R2 [*]key 314 BUTTON_SELECT [*]key 315 BUTTON_START [*]key 316 BUTTON_MODE [*]key 317 BUTTON_THUMBL [*]key 318 BUTTON_THUMBR [*]# key 352 "KEY_OK" [*]key 353 DPAD_CENTER [*]# key 354 "KEY_GOTO" [*]# key 355 "KEY_CLEAR" [*]# key 356 "KEY_POWER2" [*]# key 357 "KEY_OPTION" [*]# key 358 "KEY_INFO" [*]# key 359 "KEY_TIME" [*]# key 360 "KEY_VENDOR" [*]# key 361 "KEY_ARCHIVE" [*]key 362 GUIDE [*]# key 363 "KEY_CHANNEL" [*]# key 364 "KEY_FAVORITES" [*]# key 365 "KEY_EPG" [*]key 366 DVR [*]# key 367 "KEY_MHP" [*]# key 368 "KEY_LANGUAGE" [*]# key 369 "KEY_TITLE" [*]# key 370 "KEY_SUBTITLE" [*]# key 371 "KEY_ANGLE" [*]# key 372 "KEY_ZOOM" [*]# key 373 "KEY_MODE" [*]# key 374 "KEY_KEYBOARD" [*]# key 375 "KEY_SCREEN" [*]# key 376 "KEY_PC" [*]key 377 TV [*]# key 378 "KEY_TV2" [*]# key 379 "KEY_VCR" [*]# key 380 "KEY_VCR2" [*]# key 381 "KEY_SAT" [*]# key 382 "KEY_SAT2" [*]# key 383 "KEY_CD" [*]# key 384 "KEY_TAPE" [*]# key 385 "KEY_RADIO" [*]# key 386 "KEY_TUNER" [*]# key 387 "KEY_PLAYER" [*]# key 388 "KEY_TEXT" [*]# key 389 "KEY_DVD" [*]# key 390 "KEY_AUX" [*]# key 391 "KEY_MP3" [*]# key 392 "KEY_AUDIO" [*]# key 393 "KEY_VIDEO" [*]# key 394 "KEY_DIRECTORY" [*]# key 395 "KEY_LIST" [*]# key 396 "KEY_MEMO" [*]key 397 CALENDAR [*]# key 398 "KEY_RED" [*]# key 399 "KEY_GREEN" [*]# key 400 "KEY_YELLOW" [*]# key 401 "KEY_BLUE" [*]key 402 CHANNEL_UP [*]key 403 CHANNEL_DOWN [*]# key 404 "KEY_FIRST" [*]# key 405 "KEY_LAST" [*]# key 406 "KEY_AB" [*]# key 407 "KEY_NEXT" [*]# key 408 "KEY_RESTART" [*]# key 409 "KEY_SLOW" [*]# key 410 "KEY_SHUFFLE" [*]# key 411 "KEY_BREAK" [*]# key 412 "KEY_PREVIOUS" [*]# key 413 "KEY_DIGITS" [*]# key 414 "KEY_TEEN" [*]# key 415 "KEY_TWEN" [*]key 429 CONTACTS [*]# key 448 "KEY_DEL_EOL" [*]# key 449 "KEY_DEL_EOS" [*]# key 450 "KEY_INS_LINE" [*]# key 451 "KEY_DEL_LINE" [*]key 464 FUNCTION [*]key 465 ESCAPE FUNCTION [*]key 466 F1 FUNCTION [*]key 467 F2 FUNCTION [*]key 468 F3 FUNCTION [*]key 469 F4 FUNCTION [*]key 470 F5 FUNCTION [*]key 471 F6 FUNCTION [*]key 472 F7 FUNCTION [*]key 473 F8 FUNCTION [*]key 474 F9 FUNCTION [*]key 475 F10 FUNCTION [*]key 476 F11 FUNCTION [*]key 477 F12 FUNCTION [*]key 478 1 FUNCTION [*]key 479 2 FUNCTION [*]key 480 D FUNCTION [*]key 481 E FUNCTION [*]key 482 F FUNCTION [*]key 483 S FUNCTION [*]key 484 B FUNCTION [*]# key 497 KEY_BRL_DOT1 [*]# key 498 KEY_BRL_DOT2 [*]# key 499 KEY_BRL_DOT3 [*]# key 500 KEY_BRL_DOT4 [*]# key 501 KEY_BRL_DOT5 [*]# key 502 KEY_BRL_DOT6 [*]# key 503 KEY_BRL_DOT7 [*]# key 504 KEY_BRL_DOT8 [*]# Keys defined by HID usages [*]key usage 0x0c006F BRIGHTNESS_UP [*]key usage 0x0c0070 BRIGHTNESS_DOWN [*]# Joystick and game controller axes. [*]# Axes that are not mapped will be assigned generic axis numbers by the input subsystem. [*]axis 0x00 X [*]axis 0x01 Y [*]axis 0x02 Z [*]axis 0x03 RX [*]axis 0x04 RY [*]axis 0x05 RZ [*]axis 0x06 THROTTLE [*]axis 0x07 RUDDER [*]axis 0x08 WHEEL [*]axis 0x09 GAS [*]axis 0x0a BRAKE [*]axis 0x10 HAT_X [*]axis 0x11 HAT_Y [/LIST]
To do this:
Open ES File Explorer..
Select menu-> Switch on Root Explorer under Tools.
Again click on Root Explorer.
A pop up window will appear.
Select Mount R/W -> Select RW option from the new popup for '/' and 'system'.Last edited by cabrinha; 20 March 2015, 17:50.
Hi to all, today I finally recieved my tablet and now I want your help.
B1451 in serial 32GB with a rom from UK without Chinese apps ( clean ) .
I first wanted to backup my rom my IMEI nvram etc, before I will try to flash bigger partitions, recovery, and custom rom.
I checked Usb debugging, and also all my drivers for storage, preloader, Meta mode are installed correctry , I have also a MTK 8389 device too.
Using MTK Droid tools I could not have root access through root button, so IMEI/NVRAM backup and Blocks Map -- scatter file creation was dimmed.
So I tried to root using root genius. After 5 times of rebbooting through root genius I had the message, very touch device, I cannot root it.
This is my first device root genius cannot root a device. After I tried mmrrdd's root file via stock recovery, it rooted ok, I had super su installed, but with MTK Droid tools pressing root button , I had error message, I could not have root access.
Then I tried root genius again ask supersu to give access to root genius, it succesully rooted this time, I have root access through MTK Droid tools but still IMEI backup and scatter file creation was dimmed.
Then I made a backup of my tab using MTK Droid tools, and one more time using SP flash tools and readback option.
Backups created perfectly.
Next step was to flash recovery and EBR files, I flashed TWRP_2810_light_LEPI+newTheme.zip extracting the recovery.img perfectly, the I tried to flash first the Ebr 13gb kitkat, using EBR1 and EBR2 through SPflash tools, I got a tablet not booting stock in chinese logo, I tried to flash it through recovery, the same problem, I tried the Ebr 10gb kitkat the same problem both ways.
Flashing my EBR1, EBR2 from my back tablet booted ok, The I flashed partition_6gGIG.zip from this forum extracting EBR1 EBR2 with flash tools, I got a perfectry booting tablet with 6GB internal space, and after formating I see and the rest as internal SD
Because I install a lot of apps is there a way to have the about 26GB I have split in two pieces?
Has anyone managed to make the 13GB or 10GB partitioning to work in 32GB model?
I cannot extract my scatter due to dimmed buttons, has anyone a better idea
I also tried to root again with root genius but the same happens.
Thanks in advance
EDIT: Made wipes installed Lepi's U65GT_V2.0.4B_Lepi_150115.zip it is working just fine, superuser installed ok, apps are granted su access BUT the problem at MTK Droid tools remain " IMEI/NVRAM backup and Blocks Map -- scatter file creation was dimmed."
And also ofcource I had managed to get 6GB internal partition no more ( I wished 13GB )Last edited by leotzian; 20 March 2015, 16:04.
I'm only on mobile this weekend so I don't have time to look at this issue. I will check tomorrow.
I see you got help with EBR files from other thead. Try them. Also check that you have latest SU binaries instelled. You can always use Link2Sd method for bigger app space. It is not as good as EBR files method but it is working.
But thanks for sharing the file
UPDATE:
Since the zopomobile patches ended up to bootloop, I have deleted the link from first post. Sorry for people who suffer this problem. There is now new patches (10Gb and 13Gb) made by azaotl and linuxovios. Those patches has been comfirmed to work with Talk 9X 32Gb tablet (thanks to leotzian for testing). I don't know if they work with 16Gb.
I did also add info "how to fix external keyboard issue" link. I was already forgotten that problem so that is why it wasn't added earlier.Last edited by Vohukain; 23 March 2015, 08:42.
There are currently 3514 users online. 0 members and 3514 guests.
