Justme ROM v1.6c dual boot either spmc / kodi Change log
- SPMC koying 13.4.0.
- kodi launcher compiled by me, kudos to blunden for the source to modify.
- fixed the black screen after flashing bug.
- cleaned up the ROM, so it should be more stable and smoother.
- eliminated some apps, this sway user can install what they want and it more compact.
- I belive its fix the samsung tv issue from what I been told.
Known Issues
- intial flash there is 30 to 90 second blank screen while box configs it self.
- Once you get the green config screen allow the box to config 90 seconds
Instructions
As always either toothpick recovery or via the Android UI update/back up tab. if you have issues with remote then goto this thread and download your appropiate remote patcher to update saves me having multiply ROMs and saves bandwidth http://www.freaktab.com/showthread.p...l=1#post232007
All tech related question post away here on forum, any I did not get the link, check your junk/spam box or create a new support ticket on www.justmeroms.com and keep all the i did not get the link of the tech forum.
Older thread will be retired as from today or when mods or admin get to it.
Download : http://bit.do/justme1-6cc
