which xbmc spmc or kodi? and please anyone else have this issues.
Justme v1.6c s802, 2gb, ap6330, 8gb ROM [Now Public]
Originally posted by sparkymark79 View Post
which xbmc spmc or kodi? and please anyone else have this issues.Bugs are Sons of Glitches!
JustMe
JustMe
Originally posted by JustMe View Postjust loaded istream and pheonix working ok for me spmc
Originally posted by userofthenet View PostRunning kodi 14.1 and no script error on genesis or istream. I don't have vevo. The only problem I noticed is that if I wake the box from sleep it freezes. Installed a different launcher and waking up from sleep is OK but trying to start kodi sometimes freezes the box and have to unplug and plug back. I didn't have this issue with 1.6b and kodi 14.0. I didn't really use spmc. Also, I still have the bug where the box freezes after waking up from sleep when using wifi. Using ethernet doesn't produce this issue. Otherwise the rom is great and as smooth as 1.6b. Thanks justme.Bugs are Sons of Glitches!
JustMe
Originally posted by JustMe View PostI can't say that i can replicate the freeze after sleep on original m8, might try the m8n that i have here sent to me by apostle.
Originally posted by sparkymark79 View Postwhat can i provide so you can see what it causing the script errors. how do i do logging?
i'm annoyed that i'm going to have to go back to 1.6b as i got that working.
OI can't understand what I have done differently to get the errors
JustMe
Originally posted by userofthenet View Postmake sure you are using wifi because the box is OK with ethernet. Btw, this not an issue for me. Just reporting the bug. This bug is not unique to your roms. It is also happening with mediaman, latest stock rom and recently megatron. I tried so many roms and justme ROM are so far the best for me (EM8). Btw, the ethernet speed on 1.6c is really fast. 50mb down and 52 mb up. This maxed out my service. The wifi speed was 10mb down and 15mb up. I like the new app for accessing freak tab. Shows the forum on full screen.
1.6c released now to public for members 1.5v3 due out in 24 to 48 hrs sorry for delay final fixesLast edited by JustMe; 02-21-2015, 07:05.Bugs are Sons of Glitches!
JustMe
M8N install
JM. Kudos, once again. Had no problems installing this to replace Port 1.5 v2. I do not want to boot into Kodi all the time, so I installed Nova launcher from within Kodi and changed launcher settings there. Again, no issues. SD card write is working well. The remote zip fixed the buttons as expected. Your boot screen is crisp and clean. Restored Kodi from a backup and was operational withing an hour of the install.
I am having a some issues with dragging widgets to the desktop. Some do, some don't. Also additional wallpaper apps do not launch. ES Explorer does and allows .jpg use. I know that this release is a media version and meant to boot into Kodi, so these are very minor.
A beer is coming your way as soon as I run some other apps... cjNvidia Shield (2017 & 2019), A95x Max, WD EX2 NAS
Originally posted by tdcompuservices View Post================================================== ===========
1. The blank screen stay too long it over 1 minutes, after "JustMe Rom's" animation.....THAT NOT GOOD
2. Stuck at Kodi Launcher Settings, won't go nowhere...Press RETURN button on remote control NO HELP
Press HOME button NO HELP.
3. Unlugged power connection and plugin...Box boot back to previous screen (KODI LAUNCHER SETTINGS).
4. Downloaded M8N_new_remote and flashed........Complete
5. Box rebooting and go direct back to "KODI LAUNCHER SETTINGS", after "JustMe Rom's" animation
WHAT NEXT? ANY ADVISER?
1. Flashed 1.6c again..................(Blank screen still up to within 1min)
2. This time select SPMC (Once) (Go smooth...)
3. Install Kodi 14.1 (Official released on kodi.tv)
4. Reboot the box............
5. Now select Kodi launcher (once) (Hummm prefect..smooth)
6. Reboot box and select Kodi (Always)
7. Reboot and everything prefect (From "JUSTME ROOM'S" animation goto kodi took about 3 seconds)..........Humm what change and what is a big different).
By the ways, BAD news
1. HOME button doesn't work (Doesn't go back to Android Apps screen)
2. Volume go UP each time press on HOME button
I will update as soon as I have issues.....!
I am back........
1. Within 10 - 20 minutes, a Big black screen pop out and covered while watching the movie...(This is not happen on M8N box with had stock firmware)
Justme Keep up the good work! slightly stuck here though - please help
OK here goes, I have put the firmware on to my M8N, then updated with the new (square remote) all OK.
so now I have the two options to either go to Kodi Launcher or SPMC.
I would like to put Kodi 14.1 however I cannot get to the android apps menu as you normally would when pressing the home button. My Home button does work correctly since the new remote update but when pressing that from being inside SPMC it only returns to the Select Home App screen where you have the option again to go into the launcher or SPMC.
What I need to do is get to a web browser on it and then the download section which I cannot work out how to do?
please any help would be very appreciated?
many thanks
Glenn.
There are currently 2103 users online. 5 members and 2098 guests.
