Justme v1.6c s802, 2gb, ap6330, 8gb ROM [Now Public]
Originally posted by cjeman View Post
Originally posted by localpcfix View PostBugs are Sons of Glitches!
JustMe
many thanks! all working on the M8N perfectly! only thing now is ......
I'm trying to do the same thing on my M8 and I cant even get it to get the firmware on there, I have tried the reset button inside the MIC/JACK port and the box just keeps booting up and not jumping into the firmware update like the M8N did, so I thought I'd try the OTA Update app on it and all went well, it gave me the warnings that it will wipe box etc and then proceeds to reboot. and thats it it just reboots and comes straight back up into Android menu....
any advice is appreciated...
many thanks and kind regards
Glenn
Originally posted by localpcfix View PostI'm trying to do the same thing on my M8 and I cant even get it to get the firmware on there, I have tried the reset button inside the MIC/JACK port and the box just keeps booting up and not jumping into the firmware update like the M8N did, so I thought I'd try the OTA Update app on it and all went well, it gave me the warnings that it will wipe box etc and then proceeds to reboot. and thats it it just reboots and comes straight back up into Android menu....
Glenn
I hav etested this on m8n and m8 both working and virtually same box with some cosmetic changes and remote, can you take picture and post at the end of the flash black screenBugs are Sons of Glitches!
JustMe
Originally posted by JustMe View Postdoes it flash and give you complete with 0- 10000dec or do you get error at the end of the flash.
It doesn't even enter the flashing screen, you get the Mali 450 Logo, then straight after it comes up with the gif MBOX - Make Your Life Color
No errors no nothing, its just I have rebooted the box??
Originally posted by localpcfix View PostIt doesn't even enter the flashing screen, you get the Mali 450 Logo, then straight after it comes up with the gif MBOX - Make Your Life Color
put recovery.img on root of usb stick and do the toothpickBugs are Sons of Glitches!
JustMe
Originally posted by localpcfix View PostOK i'll do that now, just got to find recovery.img lol, I'm fairly new to this sorry
also visual guide and instructions http://justmeroms.com/support-page/Bugs are Sons of Glitches!
JustMe
Originally posted by JustMe View Postcan i ask did you extract the downloaded zip file and stick all files on sd card or usb?
little green man with a spinning heart now..... ill report back on what happens.....
Originally posted by eikum View PostJustMe:
Did you remove the FrequencySwitcher? Why is that?
I also have a problem with downloading from Google Play, it just say downloading and nothing happens.
any tip?
also google playstore maybe try this method posted by another member
JustMe
Originally posted by okey View Posthas the wake up issue been sorted with this version, or do i have to run wakeme scottie every timeBugs are Sons of Glitches!
JustMe
Originally posted by cjeman View PostJM. Kudos, once again. Had no problems installing this to replace Port 1.5 v2. I do not want to boot into Kodi all the time, so I installed Nova launcher from within Kodi and changed launcher settings there. Again, no issues. SD card write is working well. The remote zip fixed the buttons as expected. Your boot screen is crisp and clean. Restored Kodi from a backup and was operational withing an hour of the install.
I am having a some issues with dragging widgets to the desktop. Some do, some don't. Also additional wallpaper apps do not launch. ES Explorer does and allows .jpg use. I know that this release is a media version and meant to boot into Kodi, so these are very minor.
A beer is coming your way as soon as I run some other apps... cj
There are currently 2287 users online. 6 members and 2281 guests.
