any help would be great and thank you .
tronsmart vega s89-h need help
hi all masters of the tronsmarts box . I had a vega s89h for months no problem but last few weeks I unplugged the power cord for few days for moving ,now I plugged the power cord back in , I had no power light at all , I tried the tooth pick , power button on the side , still no show . I wonder what might happened ?
any help would be great and thank you .Tags: None
Originally posted by thamdo View Posthi all masters of the tronsmarts box . I had a vega s89h for months no problem but last few weeks I unplugged the power cord for few days for moving ,now I plugged the power cord back in , I had no power light at all , I tried the tooth pick , power button on the side , still no show . I wonder what might happened ?
Please don't worry, tronsmart entrust us to handle the vega s89 problem and you can send us PM for more detail, we would love to help.
EricLooking for developers
Also, try other receptacles/outlets in your home?
Make sure the plug you are plugging the AC Adapter to, is not being controlled by a wall switch.
Good luck.
Originally posted by geekbuying View Posthave you tried to connect with your pc? and try to flash the firmware again?
Eric
Originally posted by RISCy Dude View PostDo you have a way to see if the AC Adapter is working? A multimeter can be had for less than $10(US)
Good luck.
dead s89
Good luck.
Originally posted by greg dinning View Postbe sure you replugged with original 5 volt plug , i've had customers try a plug "because it fit" and fry their box with 12 volts. I agree that size and power should coincide but...
Did that with my older cell phone I used to have. Was at my Moms house and it was going dead, I THOUGHT she had the same phone I did and she offered to let me use her charger. It fit, phone went nuts, turns out same plug, different phoneIt was pretty much scrap at that point but we had the replacement policy and they gave me another one
Guy was trying to get any data off it for me and asked if I plugged it in to the wrong power supply or something too as it's memory was blank
Gotta be careful, very easy mistake to make with the devices that use the barrel connecters as it can be the right voltage and all that but wrong polarity too.
There are currently 4190 users online. 0 members and 4190 guests.
