[ROM] Unofficial OpenELEC for MK808B+ and MXQ
ok i seem to have fixed the problem finally, i reverted back to 6.0.1.1 and went to openelec settings, then network, and turned wired networks off. then i enabled "wait for network before starting kodi" and set the timeout to 60. i have done several hard reboots and the wifi driver seems to be loading each time. will continue to test...
Originally posted by kszaq View Post[USER="78902"]
@Everybody It seems like your lockup issues with newer boards may be scaling governor and CPU voltage related. Amlogic bumped voltages for higher CPU frequencies a bit in their latest release (which is not that easy to find, unfortunately) so we may try if that fixes anything. I'm a bit busy this week so I need to ask you for a bit of patience.
Originally posted by kszaq View PostIf you can wait a few hours then I'll post a test version with bumped voltages so you can test it from an SD card.
Originally posted by jed View Post
Yes that would be great, thank you ! I guess the Android bumps the voltages at the moment then, that why that works ? Will the SD version boot with stock Android bootloader ? Thanks.
Bumped voltages are my guess why OpenELEC doesn't work, it may as well be something else. Do you have factory firmware image for that box? I may have a look if the voltages are bumped. They are set in device tree. As for bootloader, I recommend keeping a factory one. SD version should work fine after applying uenv update.
kszaq It wont let me upload it here, (says invalid file format) I tried zipping it too and tried a few times. Can you PM me an email address and I can email it to you ? EDIT: I found a 24hr expiry place to upload it to. It is at: https://dropfile.to/gLeH0 Thanks. hope you see the EDIT kszaqLast edited by jed; 11 February 2016, 18:46.
MXIII (with a red [4K] on top)
I have loaded this Openelec on my MXQ boxes without issue. Now I am pondering the MXIII...
I was wondering if anyone has tried the firmware on a MXIII? They seem to have similar specs, just more RAM.
If you did, which version? MXQ or the HD18Q (which I think is mostly a remote.conf change)
Originally posted by jed View Postkszaq It wont let me upload it here, (says invalid file format) I tried zipping it too and tried a few times. Can you PM me an email address and I can email it to you ? EDIT: I found a 24hr expiry place to upload it to. It is at: https://dropfile.to/gLeH0 Thanks. hope you see the EDIT kszaq
Originally posted by phinc View PostAnybody had any luck with Anynet+ (HDMI CEC implementation on Samsung TVs)?Code:echo 0x0 > /sys/class/amhdmitx/amhdmitx0/cec_config echo 0xf > /sys/class/amhdmitx/amhdmitx0/cec_config
Originally posted by kszaq View Postjed I have downloaded your kernel and looked at DVFS table. Your voltages are the same we use in OpenELEC so issue may be somewhere else. You may want to try a test release with bumped voltages if you want: http://s805.eu/test/6.0.1.2-test1/Last edited by jed; 11 February 2016, 21:52.
Guest OK thanks for looking. I tried it, it didn't work. I flashed the uenv first and then booted off SD. Froze straight away and would occasionally unfreeze but 99% frozen, same as normal voltage. Thanks for trying, I will probably return it. Funny thing is, its fine on Android.
There are currently 2928 users online. 1 members and 2927 guests.
