It worked fine at the beginning, but as i wanted to try Finless rom 1.6b, I am now left with a non-working device.
Long story short:
Whatever ROM I try, I am stuck with a constant reboot:
For finless rom 1.6b and 1.5 - TV recognizes the device and input for about 5 seconds, then it looks like I have disconnected the HDMI cable, so it does that over and over again. No images on screen.
Original 4.4 and 4.2.2 Roms:
With 4.4 I got for penguins on the screen with the same behavior (constant reboot)
For the 4.2.2 by Tronsmart, i get the Tronsmart logo on screen with the same behaviour (constant reboot).
Long story
I first started on a windows 8.1 machine. Everything went smoothly with the drivers, i got the NAND Erased, but when I tried to flash the rom, it failed on the first reset. After that Windows threw Code 43 in my face and would not recognize the device anymore.
So I installed Win7 on my mac with Parallels and I was able to reflash the device - with the issues presented here. I tried a combination of kernels and boots form the Finless 1.6b package to no avail. Also, the weirdest thing was that the flash tool in 1.6b folder would flash the ROM without errors and then boot back to flash mode - which was weird.
The RKBatch tool did everything correctly (that's what I used for the stock 4.4 and 4.2.2), and booted to normal mode with which I get at least an image on screen.
The Flash tool in 1.5 Booted to normal mode, but still - nothing on screen just constant rebooting.
I got my hands on a real win7 laptop today, so I will try everything again. Also found something called the "rescue rom", So I will give that a try. But if anyone could point me to the right direction, what could be the problem (I'm thinking kernels?) and what to do about it, it would be greatly appreciated.
A screenshot from the sellers page with system info: If anyone finds it helpful and could point me to the right direction, it would be great. Right now I have just a really expensive stick that I could throw to a dog.
