Anyway, I was trying to find the value (625MHz) in both little-endian and big-endian formats, but no luck. Either they are encoded in some weird format, or the max frequency is saved as some other value.
I also tried to find some decompilers for ELF files, but no luck either. They are compiled with gcc, and have similar content as resource files (string tables, etc.). That's all I found.
But. I did found one potential offset which have a word (2-byte) value encoded in little-endian format. The value is in Mhz ("625"), and it occurs only once throughout the whole file. Still, I'm not sure whether it's the right one, and what consequences would it have after flashing it back.
I will think about it a bit more (and for VPU too), but I would also appreciate some other viewpoints. Thanks.
