HPH overclocked kernels by Burs
Guest
Originally posted by Gormar View Post- especialy at 700mhz which might even fall back to 648mhz where 1.175V is enough. Just a thought from my experience.
Originally posted by man View Post
Originally posted by Burs View PostJust a few notes on frequencies. 12% increase for cpu isn't much, you'll just get a placebo effect. And please don't abuse your [email protected]- especialy at 700mhz which might even fall back to 648mhz where 1.175V is enough. Just a thought from my experience.
As for DDR memory. Even if it is LPDDR3 type it can easly perform at 1.5V as backward compatibility (it is so with Kingston modules). And I like to be safe than sorry. But every one should experiment with his own box and find propper settings for it.
I knew that RK3288 CPU set to 1.8 GHz isn't much but even with mounted fan in my closed BOX CPU arrives at 95C quite fast (~5 minutes) and then it start throttling. For now I don't see any necessity to OC more.
As for DDR memory. Even if it is LPDDR3 type it can easly perform at 1.5V as backward compatibility (it is so with Kingston modules). And I like to be safe than sorry. But every one should experiment with his own box and find propper settings for it.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Guest
Originally posted by Gormar View PostI know that RK3288 CPU set to 1.8 GHz isn't much but even with mounted fan in my closed BOX CPU arrive at 95C quite fast (~5 minutes) and then it start throttling. For now I don't see any necessity to OC more.
Originally posted by Gormar View PostAs for DDR memory. Even if it is LPDDR3 type it can easly perform at 1.5V as backward compatibility (it is so with Kingston modules). And I like to be safe than sorry. But every one should experiment with his own box and find propper settings for it.
Originally posted by Burs View PostLast time I checked Rockchip's specs, RAM was rated at 1.3V max. You might go above that into unsafe voltages, but I wouldn't recommend it. 1.275V is enough even for ddr@800mhz, so why giving overvoltage without any reason?
Are you realy sure that RK3288 can only support 1.3V memory? It will not work with standard 1.5V DDR3 modules but only with LPDDR3?
Another problem is that I do not realy know with what voltage Beelink R89 MIRA (LP)DDR3 memory modules work. Output voltage from ACT8846 regulator can be easly changed by replacing one resistor in output feedback loop. And then without multimeter or magnify glass you will never know what voltage it realy supply to chosen components.
P.S.
I forgot that I have datasheet for P3P4GF4BLF-GGN MIRA DDR3 modules used in Beelink R89 (nexteon board). Absolute maximum rating for VDD is 1.975V therefore 1.35V * 1.25 (feedback voltage divider) = 1.6875V isn't going to damage them but overheating might.
P.P.S.
I've just checked in RK3288 datasheet that absolute maximum rating for DDR_VDD is 1.65V. Oops. I probably crossed it a bit
. Also it is good to remember that CPU_VDD and GPU_VDD max is 1.4V.
Last edited by Gormar; 23 March 2015, 21:35. Reason: information about maximum voltage for componentsRK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Well, i tried to use Gormar app but in terminal it says I have no permission (?). I have even used the SU command so I have root access. Don't know what could I be doing wrong...
Maybe, it's because I have a firefly board and not r28 (Android not build for the firefly board?). Any problem in EMMC?
I don't know
@man. I updated my instruction for you to avoid placement of overclockmatick_RK3288.elf file into /mnt/sdcard directory. Because it will "land" on FAT file system or emulated storage. Both cannot be used for executable files.
You can extract overclockmatic_RK3288.elf file to /data/ path but remember to use EZ File Explorer with "Root access" enabled.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
I know this has been covered, but can't seem to find it. Isn't there a way to cat a file to get proper cpu temp?
Can anyone help me out on that one? I've been watching Doctor Who in Firefox and was curious about the temp. Surely it must get warm sometimes but my R89 hardly ever feels warm externally on the top or bottom of the case.
Thanks!
-SB---------------------------------------
Currently using U-BOX R89 with mo123 v1.6.
Other android tv device - ADT-1 running latest PureNexus 6.0.1 MM and very impressed with the changes vs stock molly!
Pipo M9S -- CrewRKTab custom rooted 4.4.2
RCA Viking Pro 10 -- Custom stock rooted 5.1 by me <- FOR SALE
----------- ROM by me, the first way to update ZTE Force 4G from ICS to JB http://androidforums.com/threads/fin...om-ics.886408/
Originally posted by sawbones999 View PostI know this has been covered, but can't seem to find it. Isn't there a way to cat a file to get proper cpu temp?
Thanks!
-SB
later--cappybob
Originally posted by sawbones999 View PostIsn't there a way to cat a file to get proper cpu temp?
Originally posted by cappybob View PostSawbones I use a an app called "CPUTemp" with my Firefly. I downloaded it from google play.
It probably reads data from /sys/class/hwmon/hwmon0/device/temp0_input. If kernel hasn't got that or path is much different then you will not get reading.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Netxeon/Beelink(?Tronsmart?) use hwmon1 (wasser use hwmon0)...RK3288 Devices
- Overview BOX (LINK !)
Guest
Originally posted by Gormar View PostThanks for the info. I didn't found application which could read RK3288 CPU temp before.
It probably reads data from /sys/class/hwmon/hwmon0/device/temp0_input. If kernel hasn't got that or path is much different then you will not get reading.It works for me with all firmwares I tried so far (HPH and custom ones).
I have heard about Xposed but it is to much trouble installing full framework just to use one module.RK3288 2GB/16GB OC 1.9GHz at 1.2V RAM [email protected] Wasser's 3.0.11 firmware
Guest
Originally posted by Gormar View PostI have heard about Xposed but it is to much trouble installing full framework just to use one module.
Xposed framework isn't that tough to install on most platforms, especially if you are already rooted(there are exceptions like the ADT-1 and some other lollipop, too, which are maybe pre-alpha status compared to experimental).
With kitkat I definitely recommend stable over experimental unless you specifically need something stable doesn't support.
I don't know if I could do without xposed
Cheers,
Everyone who has really cared about RK3288 firmware seems to be here on this topic. Go to Firefly wiki and look at the latest entry. There is a Lollipop Rk3288 Image available, I just got back in from a long day and have not been able to spend any time with it. Check it out guys, the downloader was Wico, so it is the real deal.
later---cappybob
There are currently 2817 users online. 0 members and 2817 guests.
