[WIP] yet another m7pro ROM
Hi everybody. I've flashed this firmware https://mega.nz/persistent/mega/t5JXEaQQ with
upgrade_tool uf over arctablet firmware.
Now M7Pro bootloops: Pipo logo, then recovery symbol. I can run recovery, but without volume buttons it's not possible to select anything except "reboot system now". OTG keyboard or mouse do not work.
upgrade_tool does not see device,
If I connect it with USB to ubuntu, dmesg shows:
[178372.232037] usb 1-2: new high-speed USB device number 76 using ehci-pci
[178514.652059] usb 1-2: new high-speed USB device number 77 using ehci-pci
while pipo reboots, but there's no any visible device on lsusb.
Is it possible to recover it?
Now I can see it with rkflashtoolkit.
What partition should I flash? Thanks!
============= 2016-01-28 14:52:33 ============
Reading flash information
Loading partition information
MACHINE_MODEL:rk30sdk
MACHINE_ID:007
MANUFACTURER:RK30SDK
MAGIC: 0x5041524B
ATAG: 0x60000800
MACHINE: 3066
CHECK_MASK: 0x80
KERNEL_IMG: 0x60408000
#RECOVER_KEY: 1,1,0,20,0
CMDLINE:console=ttyFIQ0 androidboot.console=ttyFIQ0 init=/init initrd=0x62000000,0x00800000 mtdparts=rk29xxnand:0x00002000@0x00002000(misc),0x 00006000@0x00004000(kernel),0x0000A000@0x0000A000( boot),0x00012000@0x00014000(recovery),0x00020000@0 x00026000(backup),0x00040000@0x00046000(cache),0x0 0002000@0x00086000(metadata),0x00002000@0x00088000 (kpanic),0x00180000@0x0008A000(system),-@0x0020A000(userdata)
Partitions:
misc (0x00002000 @ 0x00002000) 4 MiB
kernel (0x00006000 @ 0x00004000) 12 MiB
boot (0x0000A000 @ 0x0000A000) 20 MiB
recovery (0x00012000 @ 0x00014000) 36 MiB
backup (0x00020000 @ 0x00026000) 64 MiB
cache (0x00040000 @ 0x00046000) 128 MiB
metadata (0x00002000 @ 0x00086000) 4 MiB
kpanic (0x00002000 @ 0x00088000) 4 MiB
system (0x00180000 @ 0x0008A000) 768 MiB
userdata (0x00E7E000 @ 0x0020A000) 7420 MiB
Done!
Originally posted by raxy View Postlink for may07th version :
Because in march version all is ok/
There are these roms:
* 27th march zip file :
https://mega.nz/#!xl4gDYiT!E7GpTfM_8...VNRSgIGJeNiyfE
* link for may07th version :
https://mega.nz/#!t5JXEaQQ!CxiTNxMSw...EtXA07Q3UwduTM
What is the difference between them? On which "Pipo_M7_Pro_FreaktabROM_1.0" is based on?Also do they have all fixes mentioned in this thread, for exampleOriginally posted by raxy View Postback and front camera now take images with a correct orientation,
I will publish the fixed firmware soon
tks.Last edited by Dabolx; 19 August 2016, 16:57.
There are currently 2810 users online. 0 members and 2810 guests.
