Freaktab New Stock Rom Image 1.6
    Hello Community,
    Here we Release our New Rom for the Freakbox.
    This Rom is building from Source and Run´s Smooth and Stable.
    Fixes:
    - Fixed Lock Screen
    - Fixed Screen Blank
    - Speed Up WiFi and LAN
    - Fixed GPU Speed
    - Multiuser for 5 Users
    - Added follow programs:
    - Added Power Off / Reboot Menu
    - TWRP Recovery
    The programs we add:
    VLC
    Skype
    SuperSU
    X-Plorer
    QuickPic
    Netflix
    New YouTube
    Fixed Google Play Service Error
    FlashPlayer
    SPMC
    The XBMC Wizard we will release her later for Download.
    Download the Rom here:
    www.freak-tab.de/neomode/fb/ud_freakbox_16.zip 1GB User Space
    www.freak-tab.de/neomode/fb/fb_16_6GB.zip 6GB User Space
    www.freak-tab.de/neomode/fb/fb_16_4GB.zip 4GB User Space
    Flash it with RKBatch Tool
    Regards
    Ray aka Neomode
    Finally!
    How do I get the Freakbox into flash mode? I can boot into fastboot-mode and then the Freakbox is recognized as Rockchip USB device, but at that moment the Batch Tool still does not see the device. I also cannot find a reset button anywhere on the device, so it's a bit confusing.
    Freakbox V1 F/W 1.0.6
    Asus Zenfone 2 ZE551ML Stock (rooted)
    Samsung Galaxy Tab 3 7.0 Nolekat 2.2 custom ROM
    Asus TF300T Cyanogenmod 11 Snapshot M12
    Archos 35 Home Connect Stock 2.3.4
      The Reset Button is the tiny Hole on the bottom of the Device. Also you can Enable USB Device and then Switch the Device with Flash Tool.
        Hi Ray,
        Please explain. How do I enable USB device? I have "connect to pc" already enabled from the settings menu.
          Hello,
          Use the Android Tool [ATTACH]10823[/ATTACH].
          There you Load the Firmware.
          Then Connect the Mini USB to the Box.
          Now you should can Switch your Box to Flash Mode with the Bottom Switch.
          If not Enable USB Debugging in Developer Section.
          Ray
            I already managed to flash the ROM by using the reset button.
            I wonder why there is so little storage to install apps. Would it be possible to increase the partition size? Even better: it would be nice to install apps to external_sd, because there is plenty of storage space there. I quickly ran out of space after installing some of my standard apps and had to remove some of the apps that came with the ROM to create the necessary space.
            For now the ROM looks very stable. I'll keep on exploring it.
              Ok I change it that there is more Space to Install more Apps. Change it when coming Home.
              Also later there will be a Download for a XBMC Wizard.
                I also think there is something wrong with the mount point for external_SD. Using ES File Explorer I noticed that external_SD is not mentioned in the "Local" tab. Browsing via the /mnt folder I can access /external_SD and I can create new folders, but I cannot copy any files to the new folders.
                From FW 1.04 I remember that internal_SD and external_SD were both present in the "Local" tab in ES File Explorer.
                  nice thread, This what I was looking for
                    Hi Ray,
                    Have you made the changes without changing FW version number? If so, I will download and install again.
                      I am over it. Please give me some Minutes.
                        Uploading new Image´s with 4 and 6 GB User Space.
                        Take some Minutes.
                        Neomode
                          Hi Ray,
                          Thank you for providing me with the New Stock ROM Image, however unlike Rockko I am still confused with what to do with these files. Should I connect the box to the computer and flash it or connect it to the TV?
                          I am computer literate but not an expert with Android so I would appreciate if you could provide a step-by-step instruction with how to flash the FreakBox. I am sure there will be many other Freakbox user like me who would benefit from your instruction.
                          Many thanks,
                          Tien
                            Hello,
                            You connect the Box to the Computer and Flash the New Image in the Box.
                            The Best Image should be that one with 4GB User Space.
                            For more Information please take a look here:
                            Regards
                            Neomode
                              Why my box pops up automatically apk?
                              Hello Community,
                              Fixes:
                              - Fixed Lock Screen
                              - Fixed GPU Speed
                              - TWRP Recovery
                              VLC
                              Skype
                              SuperSU
                              X-Plorer
                              QuickPic
                              Netflix
                              New YouTube
                              FlashPlayer
                              SPMC
                              Regards
                              Ray aka Neomode
                              Howdy,
                              Recently, I don't konw why my box pops up automatically apk?
                              Regards
                              jingyan
