Thanks again for your work on these ROMs.
[REF]Complete list of (Elektrik's) Modified Stock/Custom' ROMS for Polaroid tablets
PMID 701i ROM Download
Originally posted by bob99 View PostWorks great now, thanks. And thanks for your work on these ROMs. The 701i ROM seems faster than the stock ROM (which was quite slow). If you are updating this ROM again you might want to fix the loader page where it says Polaroid 701C at the top.
Wanting to test out some 705 romsI have home button issues on both debloated stock roms after a few weeks now. I suspect the tablets did an OTA update that broke it, as both have different launchers, software, etc but both eventually had the same problem. The only thing that restores the home buttons (both hard and soft buttons) is a factory reset, which leads me to believe it is a rom issue. So, with that said, since I have to reflash anyway, might as well test one of elektric's out
Originally posted by Howie69 View PostWanting to test out some 705 romsI have home button issues on both debloated stock roms after a few weeks now. I suspect the tablets did an OTA update that broke it, as both have different launchers, software, etc but both eventually had the same problem. The only thing that restores the home buttons (both hard and soft buttons) is a factory reset, which leads me to believe it is a rom issue. So, with that said, since I have to reflash anyway, might as well test one of elektric's out
Sorry, I know that doesn't help you, it's just easier to maintain this way.
unable to flash rom
I am having a problem flashing the new rom.Livesuite does not install the new rom after following the procedures. I wonder if a driver is needed. I installed the rom previously oin a different tablet. Help..
found a live suit that works, however when I flash the new rom, I am no getting the market etc.. Is there a reason for this?
the new rom has loaded, but having difficulty access the playstore. I initially signed on. use existing account, get gplay store stoped.
any solutions?try to load the703c version but device is not recognized. How to load drivers?
i found out if you connect to your computer with the power on the drivers get loa+++++ded and the device not recognized problem goes away.
Thanks elelktrik for all your work.
Originally posted by elektrik View PostThe ROM for the PMID703C was build from the stock live suite image, and was specifically built for the PMID703C, however an adventurous person installed this image on his PTAB7XC and had zero issues (in fact, I think he's still running it), which is why I added the PTAB7XC. I do intend to build a modded image for your specific device using your stock image, but haven't done so. If you want to use this image, all you need to do is copy the PTAB's build.prop into the /system folder of my modded image, but it may just be easier to wait if you insist on having the device recognized as such.
Re: [REF]Complete list of (Elektrik's) Modified Stock/Custom' ROMS for Polaroid tablets
Hiya Elektrik. Recently got a PMID1000D. I just have a question...how would you go about editing the splash screens on this thing? The "Internetablet" splash screen kinda annoys me. I'd like to replace it with the normal Polaroid logo. If it's like I'm guessing, the splash screens are just two files in the stock ROM. If I'm correct, could you hook me up with a copy of your PMID1000D ROM with two Polaroid logos, or tell me how to edit/decompile your ROM myself?
Thanks.
Sent from my Polaroid PMID1000D using Xparent Green Tapatalk 2AndroidPizza
Originally posted by AndroidPizza View PostHiya Elektrik. Recently got a PMID1000D. I just have a question...how would you go about editing the splash screens on this thing? The "Internetablet" splash screen kinda annoys me. I'd like to replace it with the normal Polaroid logo. If it's like I'm guessing, the splash screens are just two files in the stock ROM. If I'm correct, could you hook me up with a copy of your PMID1000D ROM with two Polaroid logos, or tell me how to edit/decompile your ROM myself?
Thanks.
I'll let E talk about editing an img. But if they use live suit most of the procedures for an A10/13 should work with it, I think....but E's more knowledgeable about that
actually, it's quite easy. If you have root, just navigate to the /system/media folder. There's Bootanimation.zip (obvious), shu.zip (horizontal or vertical shutdown screen-don't remember) and hui.zip (I think?), for the other horizontal/vertical shutdown (again don't remember which is which-they're just zip files so that's easy.
Now if you're talking about the boot up LOGO, that's quite a different story and yes that's in the boot.img and no I haven't figured out a way to modify it so it displays properly :-|
Originally posted by elektrik View Postactually, it's quite easy. If you have root, just navigate to the /system/media folder. There's Bootanimation.zip (obvious), shu.zip (horizontal or vertical shutdown screen-don't remember) and hui.zip (I think?), for the other horizontal/vertical shutdown (again don't remember which is which-they're just zip files so that's easy.
Thanks anyway!
Sent from my Motorola Atrix HD using Xparent Green Tapatalk 2Last edited by AndroidPizza; 27 July 2013, 23:50.AndroidPizza
Originally posted by AndroidPizza View PostYeah, I was talking about the boot logo.
Thanks anyway!
Vocaloid fan? Check out this thread!
http://forum.xda-developers.com/show....php?t=2376692
Originally posted by elektrik View PostSure. I *have* been able to take the boot logo and make it the plain 'polaroid' though for my ROMs cause I'm with you-the ugly ass logos they put out with these tablets are just painful ha ha!
No need for an ugly rainbow everytime I turn on my tablet. Lol!
Edit: XDA link in my Sig...whoops!
Sent from my Motorola Atrix HD using Xparent Green Tapatalk 2Last edited by AndroidPizza; 27 July 2013, 23:49.AndroidPizza
There are currently 3520 users online. 0 members and 3520 guests.
