[REF]Complete list of (Elektrik's) Modified Stock/Custom' ROMS for Polaroid tablets
Originally posted by jrparker21 View Post
Originally posted by elektrik View PostOk, thanks for the info re: the 10C. Keep in mind thought that you shouldn't flash images for different models of your tab. At the very least, if you insist on doing that, you may want to at least copy off the build.prop from your stock image and then copy over the PMID10C build.prop, but again, that ROM isn't even built for your tablet.....
I went this route with the 10c image because I'm pretty darn sure the specs are quite similar (ie processor, screen size). I stumbled upon something just earlier that pointed out that the 10C has a dual camera - which could explain the lack of support for mine. The camera sux anyway.
Originally posted by jrparker21 View PostYes, I'm aware - desperation had set in (also honestly I still have up to 2 weeks to return it and am under the impression this particular tab isn't easily bricked, however don't put it passed me. I've bricked the impossible before in terms of smartphones, lol. Jtag is your friend). I get pretty ballsy sometimes...
Originally posted by Howie69 View PostThanks. Can't wait to test the next version. bloatless 705x roms would be a big hel
Originally posted by elektrik View PostOk Howie-try the new version.
https://a170132.uranus.1blu.de//data...8e.php?lang=en
That one is rooted and seems to work better than the stock so far. I am still having trouble with some apps, but I was able to install the latest google+ with huddles from apktop with no problem and got live huddles working fine on the 705x after reading another thread where you said to go to developer options and check 'force GPU rendering'. Also, on the stock firmware, I could never get play store books to work, but works fine on yours. I have a slew of other apps to test and configure, but so far so good. Now if I could just get one the for the 704 so the other kid doesn't feel left out
Originally posted by elektrik View PostJR-someone else with a PMID1000B mentioned a custom ROM to me too-I'm working on it, but patience is the order-you guys are #3 in line :-)
Just wanted to mention on here - if there is any problem with root - I am suggesting (someone else's) Polaroid All in One v1.8b - easy to find I guess with google. My file specifically read as: PolaroidAIOv1.8b It's supposed to also install the google framework with the store and google apps, I didn't need this tho as my modded rom has included this already (thanks to elektrik).
The creator suggests that it's ability is cross-platform, and it is confirmed on 2 Polaroid tablets. I have a PMID1000B, however, it read as the PMID10C - since this is the ROM I have successfully installed and am running.
This program said my tablet was rooted, however, ROM Toolbox, lucky patcher, and then the downloaded root checker (whatever it's called) said it was NOT rooted. I unrooted via this program, and rerooted successfully. It's completely capable of any customizations now.
Super satisfied
Testers for PTAB 7XC...
Originally posted by elektrik View PostUnderstood, but you *do* realize that the only way you won't be 'participating in a beta program' is if one of the developers here actually has the device and develops for it?
I'd also point out that you were the one who expressed interest in me creating a ROM, so I suppose I'm somewhat confused here....
Originally posted by Digital Dad View PostBig thanks to Elektrik and others for their efforts. I am trying to get flash to work on my daughter's ptab7xc, with no success. When you need a lab tab for the 7xc I'll be here.
Ooops!
Originally posted by elektrik View PostHmm...I've had others successfully flash the 703c ROM on the PTAB7xc....are you unable to get it to actually flash or having other problems?
Originally posted by Digital Dad View PostSorry for the confusion; Flash player. Maybe related to the CPU. Read ARM11 won't do Adobe Flash. Oddly enough one vendor says the device has Arm11, another says Cortex8??? My main concern is getting the Flash player to function on web browser. But a better, more streamlined OS is always appreciated. I believe there are tutorials here about loading ROMs. I'll check them out so I get it right the first time. Last time I did anything like this was flashing an Asustek notebook; solid state drive, from a thumbdrive. Will take a day or two, and then post results. Unless you have a less intrusive way to get Flash Player on the browser. Again, Thanks for all.
There are currently 3530 users online. 0 members and 3530 guests.
