[REF]Complete list of (Elektrik's) Modified Stock/Custom' ROMS for Polaroid tablets
Originally posted by HailingFromCork View PostHey elektrik, I just recently picked up the 705 (not the x). Would this rom work with tweaks? I'd be a more than willing beta tester.
Originally posted by greenluigi1 View PostNever mind I just installed it and it has not worked
(I like your ROM though)
Originally posted by HailingFromCork View Postthose are my two biggest concerns for now. that would be very much appreciated, thanks in advance. would i still only be able to view somewhat limited apps in the playstore that way?
LiquidLimez posted this...I don't know whether you should install ALL of the fixes (I'd just copy all the files in the /permissions folder...) to see if it worked.
Also, the version of google+ it uses doesn't support hangouts.. not sure about this. And many other apps keep reporting 'unfortunately, this app has stopped'. I did manage to get a more current google+ APK installed, but it freezes when a hangout starts, probably confused on the dual camera support
Originally posted by Howie69 View PostI know it's experimental, so I decided to test the PMID705X build. I hope this is the correct place to report it. It seems to be missing root. SuperSU updates and fails to update the su binaries, and the reboot app says "This requires root".
Originally posted by jrparker21 View PostBleh I can't find crap concerning the PMID1000B. I will SO test this if anyone is willing to cook something up.
Originally posted by elektrik View PostJR-someone else with a PMID1000B mentioned a custom ROM to me too-I'm working on it, but patience is the order-you guys are #3 in line :-)
Hey, thanks for the response. Wanted to update you with what I have done. I used your modified stock rom for the PMID10C and it's wonderful. However, 2 things:
1. There is a software update automatically after the flash. After applying this, the tablet froze at the Polaroid boot screen. So I reflashed and it's fine without the update.
2. The camera doesn't work. I personally don't care.
As far as I see, there aren't any other issues. However, I am willing to test any ROM you may provide in regards to the PMID1000B. Keep up the great work!
There are currently 3509 users online. 0 members and 3509 guests.
