OLD - UG802 2dark4u/Finless custom ROM version 1.7
I have got MK808,
I use that new firmware for ug802 to my mk808. Y
esterday and today I have got a different problem.
Yesterday , I had downloaded deadhp1's 1080p firmware for mk808, I have tried the 2dark4u &finless firmware. I tried all version, for 1080p and 720p.. I plug off the hdmi cable, and plug in again, power off, and power on again, I have changed the hdmi cable. Nothing is changed.
Please check the picture below, and suggest me, what is the solution? or what is the problem?
Best Regards
Congrats guys
My fingers are iching to start the flashing (of UG802). I never did a flash but with the help of good instruction , some good luck and a lot of divine intervention I will do it properly
Before that, I have a question. Has sopcast sound? I heard that Jelly bean is not 100% compatible with sopcast.
broken micro usb at crucial moment!
After using my UG802 on a daily basis for almost 2 months my micro usb has broken whilst flashing this 1.7 Rom. Totally Gutted.Was really looking forward to this Rom.
I don't have a soldering kit and wouldn't feel confident enough to try fixing the micro usb. As I'm currently using 1.6 that was flashed using the Flash Tool and repartitioned so I have 1 gig of internal storage, is it possible to somehow flash 1.7 via the sd card?
I think this is going to be a common issue because most mico usb connections will eventually fail on these units due to poor design.
I am using the following kernel / boot, the only issue so far is that the WiFi (signal now strong) does not let me stream content like ip security cameras (IP Camera Viewer Lite app). I can stream with Ethernet, but if I try to switch views it will hang up. One of my TVs also caused a boot loop when I powered the UG802 from its USB port. I switched to an external power supply (DC 5V 2000mA) and it stopped. Is there any danger in using a USB power supply from a tablet (like the HP Touchpad power supply, 5.3v 2A)? What is the max power supply rating that we should look for to power the UG802 running 1.7 (the min is DC 5V 2000mA correct)?
kernel_720_CPU1272_GPU466_RAM1120.img
boot720.img
Originally posted by flyer69 View PostI am using the following kernel / boot, the only issue so far is that the WiFi (signal now strong) does not let me stream content like ip security cameras (IP Camera Viewer Lite app). I can stream with Ethernet, but if I try to switch views it will hang up. One of my TVs also caused a boot loop when I powered the UG802 from its USB port. I switched to an external power supply (DC 5V 2000mA) and it stopped. Is there any danger in using a USB power supply from a tablet (like the HP Touchpad power supply, 5.3v 2A)? What is the max power supply rating that we should look for to power the UG802 running 1.7 (the min is DC 5V 2000mA correct)?
boot720.img
Tried 2gb, 6gb and 11gb mkv 1080p videos with bx player pro HW acceleration and it works perfectly in 1080p!
I just had to resize the screen a bit in settings to get rid of a small black border.
Google play works for me. I can now download apps directly from the store that weren't "supported" by the device before.
Still testing but one issue I do have (same as with 1.6) is wifi just stopping when I try to use something that needs internet access.
I can't turn it back on later.
"Sometimes" a hard reboot (disconnecting the power supply) will make it turn on and show the available APs again, but as soon as I try to connect to them (I say "them" because I have 2 routers) it will either connect but disconnect later as I mentioned, or disconnect immediately and say "out of range".
I have the ug802 case completely open with the wifi cable hanging out and one of my router which shows full signal is just 3 meters away.
I tried lowering the TX output to 25% on the router because sometimes devices jam when there is too much signal, but same issue.
Only way I can get internet access now is with a cheap usb to ethernet adapter I have.
I tried disconnecting everything from the ug802 (except for mouse) but no go.
My power supply is a 1A psu that came with it from in4dealz. It may not be 1A but I never get blackouts or anything which I do get if I connect the ug802 using the TVs usb port.
I'll try to get a 2A psu... maybe there isn't enough juice to power up the wifi chip
If you guys want I can run some tests for you.
Not sure what's going on really.
Oh, I', running kernel_1080_CPU1272_GPU466_RAM1120.img
I even tried setting the cpu to 1ghz using setcpu to see if I could get more power for the wifi chip, but nothing.
Like I said, I had the same problem with 1.6.
Not with 1.4 or 1.4a though. (never tried 1.5)
Originally posted by bads View PostJust flashed my UG802 with kernel_1080_CPU1272_GPU466_RAM1120.img and sound is not working. I can also report same problem with usb hub. When i connect mouse directly then it works, but still no sound.
Anyone have same problem? Any clues how to work this around?
Thanx
There are currently 4874 users online. 0 members and 4874 guests.
