OLD - UG802 2dark4u/Finless custom ROM version 1.7
Re: OLD - UG802 2dark4u/Finless custom ROM version 1.7
Ok, yesterday I finally got fed up with wireless problems, so I removed stock antenna, and soldered external 8dB antenna.
Checked with ohmmeter, everything looked fine.
Tested with speedtest, and I got 10Mbs, so everything looks fine...
But it works like that for about half an hour, and than drops to 800kbs. Wireless disable/enable, again 10megs. And so on..
Is this to blame on kernel, drivers, or I messed up something with antenna?? I'm running 1.7
Sent from my ST18i using Tapatalk 2
Originally posted by spectrum32 View PostAnybody reup de firmware?.Thanks.
Error 451! The page is blocked due to the decision of the authorities in your area. @media only screen { body {background-color: #ececec…
Originally posted by userx View PostHere is the original file in two different links... if one doesn't work.
http://www.filedropper.com/ug8022darkfinlessrom17
There are currently 2133 users online. 0 members and 2133 guests.
