OLD - UG802 2dark4u/Finless custom ROM version 1.7
OK just asking. My 1.7 ROM for the MK808, MX1/2 etc seems to be well liked.
You guys interested in me porting this to the UG802? Because of my numbering convention for versions, this would be 1.8 with stock kernel. But you can use any kernel you want. I wont be distributing 2dark4u's kernel with this due to his ask.
Interested?
Interested?
Finless, what device would you recommend? MK809 II? MK808? UG802? Also, do you know of a 5GHZ WIFI usb adapter to work with any of these?
Interested?
Of course interested. Support for UG802 II (BT, no reset button, but PCB labeled UG007) planned? Works OK with iMito MX1 Finless 1.5.
Yes, totally interested. Now i got one question, i installed the 1080 version because most of my videos are on that resolution, if i flash the 720 version my movies are downscaled or they are shown at 1080 (i dont like android at 1080 because its so small, and dont want to mess with the dpi because i had some bad experiences doing that on my nexus).
Is stock kernel 1080p ? I'm interested if its the case. Also, The cpu control thing is buggy in 1.7, it mixes up the min/max clockspeeds and often doesn't take on boot. I downloaded another popular one from the market which worked much better and disabled the one in the rom. I can get you the name when I go home if still required.
+1 for including the patched libstagefright.
Thanks for your great ROMs.. you are the Cyanogen of Android sticks!
So if you want it now, go ahead. Or wait till I bake it in.
1.8 is uploading now! I had to do quite a few things to test and get it working.
It will include the libstagefright.so recently released by Rockchip. I have tested it and it works.
You guys I think will love the features I put in this ROM. It's a MIX of many other ROM features and my own code to enable things like a lock screen.
Stay tuned, new post coming soon with download.
