OLD - UG802 2dark4u/Finless custom ROM version 1.7
Originally posted by Ken Hashizume View Post
Originally posted by Finless View PostI do not understand. What are these? Is this from the new model UG802?
It extracts from the new model UG802 by rkdump.
Since only kernel.img and boot.img were extracted, kernel.img and boot.img were raised.
WIFI could be used, when burning Finless custom ROM version 1.7 by ROM Flash Tool, and kernel and boot were changed into this kernel.img and boot.img and were burned.
However, only 720P can be used.
Is it made not to have Bob and this outputted 1080P?
I also have this newer version of the UG802...
Hi all, I joined the forums because I just ordered and received a UG802 and wanted to flash a custom ROM on it, the new finless v1.7. However, when I opened the case, I saw that I too have different hardware than the original UG802. Pics in the link below.
As taxpayer and Ken stated, the two solder pads near the NAND chip have been replaced by a button. Also the PCB has the date 20121018 and version SW601 v0.1 printed on it. The wifi chip is imprinted as Realtek RTL8188EUS. Also, you will notice that the antenna is different than ones I have seen pictured in the past (no foil). To be honest, the wifi reception is really strong. I dunno if it's the antenna or what, but I got excellent speeds with the speedtest app.
If I can be of any service in getting 1.7 working on this hardware version, I'd be happy to help and/or donate. I see that ken has uploaded a ROM dump, but I'm not sure if that will work. If given some instructions, I'd be happy to also supply one. Ken also mentioned (with rough English) that it's possible to get v1.7 working on this with wifi, depending on what you flash and the order (something about not powering it off). If so, can anyone provide clear instructions, or should I wait for a completely updated finless ROM? The stock ROM on this is garbage.
Thanks for all you guys do!Last edited by leroy_sunset; 11 January 2013, 23:17.UG802 with the newest hardware... waiting on a new ROM by the infamous Finless Bob!
Originally posted by leroy_sunset View PostHi all, I joined the forums because I just ordered and received a UG802 and wanted to flash a custom ROM on it, the new finless v1.7. However, when I opened the case, I saw that I too have different hardware than the original UG802. Pics in the link below.
It is the same hardware as UG802 which I have partly.
It seems that however, ROM is different.
There was no power button in my ROM to system bar.
Originally posted by Finless View PostKen, I would like ther full ROM... Can you dump backup.img partition please?
If it carries out, how can it extract?
Dump mountedblock 4 (mtd4). If you have root you should be able to.
Oh I see you got unknown image! This is a priblem with RKDump and RK3066. Do you have a linux box?
Or dump it using ADB using DD command.
Originally posted by Finless View PostDump mountedblock 4 (mtd4). If you have root you should be able to.
backup.img was able to be extracted by DD command.
http://dl.dropbox.com/u/19217064/backup.img
Your fast.... I think you have done this before?
I am impressed
Ken stated his ROM was labeled as:
rk30 sdk-eng4.1.1 JRO03H eng.box.20121126.180852 test-keys
Mine is labeled as:
rk30sdk-eng 4.1.1 JRO03H eng.box.20121208.221744 test-keys
Looks like the hardware is the same? Once again, happy to do a ROM dump if given some instructions. I see that you must have root access, and use the rkdump tool.UG802 with the newest hardware... waiting on a new ROM by the infamous Finless Bob!
Mine is labeled as:
The inside of the five pieces and two pieces are "rk30 sdk-eng4.1.1 JRO03H eng.box.20121126.180852 test-keys."
Although it came out and three pieces were "rk30 sdk-eng 4.1.1 JRO03H eng.box.20121208.221744 test-keys", "Finless custom ROM version 1.7" is overwritten, There is no ROM of "rk30 sdk-eng 4.1.1 JRO03H eng.box.20121208.221744 test-keys", One set which remained extracted ROM by "rk30 sdk-eng4.1.1 JRO03H eng.box.20121126.180852 test-keys" after this.
SO this dump which you did properly is not the full ROM! However from it I did extract the parameter file!
So please... I have boot.img and kernel.img. I need system.img. Do not worry this is not data I can steal from you. As long as you do not dump /data all is secure! even if it was not, I wild not steal your information.
So can you please dump with DD system.img.
Thanks,
Originally posted by Finless View PostCRAP.... this sometimes is the case. The manufacturer DID NOT put the full ROM into backup.img
Thanks,
It was out at work and became late.
Thank you Ken!
Downloading now.
No worries about late reply... People will love you for supplying me this ROM!
YOU ARE THE MAN!
windows 8 drivers
Guys i have a fresh copy of windows 8 doing the whole process to install the new firmware on my ug802 i m getting in flash mode but when i continue to install the drivers in win8 they didnt install because they are not compatibles i think.Is there any other way i can install drivers for windows 8??
There are currently 2215 users online. 3 members and 2212 guests.
