I have connected 2 wireless joypads to the hub. The hub is connected to the usb port. Although both joy pads works in MAME emulator, they works as they were the same. I mean, I configure player 1 controls with joypad 1 and when I configure player 2 controls with joypad 2, player 1 control are deleted because both joypads have the same controls, they are detected as the same joypad. Can anybody help me?
OLD - UG802 2dark4u/Finless custom ROM version 1.7
I CANT CONFIGURE 2 JOYPADS ON MY UG802
Originally posted by bakos1978 View PostIs there any other way i can install drivers for windows 8??
Works for me with real Win XP in Virtualbox because I'm using OS X. Only had to activate a Win XP netbook when I needed to revive my U30GT. Couldn't properly short the pins, connect USB and then use good timing for passing through the USB connection - at the time I got there, the device was already gone
Originally posted by bakos1978 View PostGuys i have a fresh copy of windows 8 doing the whole process to install the new firmware on my ug802 i m getting in flash mode but when i continue to install the drivers in win8 they didnt install because they are not compatibles i think.Is there any other way i can install drivers for windows 8??
I guick find some tutorial for you...http://laslow.net/2012/03/14/disable...-in-windows-8/
clone ug802 posts moved
Ken and Alex, I have moved the posts about the new model "clone" UG802 to here:
http://www.freaktab.com/showthread.p...different-wifi!!
Re: UG802 2dark4u/Finless custom ROM version 1.7 - true 1080 and overclock - AND best performance ever!
Now my UG802 begin restart on every use of mxplayer or other players.
Everything work well 2 month,use stock kernel and image.
Still not got sound on 720 &1080 kernel.
Sent from my GT-I9300 using Tapatalk 2
Broken USB unable to flash
Hi my Micro USB port is broken.
I am on 14.a (upgraded via SDCard)
I am trying to upgrade to 1.7 via a regular usb cable.
I installed droidvnc server so that I can control the UG802 with my laptop. As soon as I click on connect to PC the remote vnc server stops working and I cannot do anything else.
If I power it via a hub the tool will not recognize it.
I have tried to reboot to bootloader and recovery but that did not help either.
Any suggestions?
Varun
Any suggestions?
Varun
Be sure to read the whole thread as there was some confusion over green and white connections.
Good luck
......I've just found this in another post.....
....So, in future, it may be possible to update with SD card update image....if you don't fancy soldering!Last edited by Sniglar; 15 January 2013, 15:46.
Originally posted by Bonell View PostHow can I tell if I have a older or recent version (clone) of the UG8302? I flashed 1.7 and everything is great.. apart from the wifi wich is very weak (if I have the router in another room). The symptoms are very weak wifi signal , or no signal at all? Thanks Guys.
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
Originally posted by mrrog View PostWithout me having to look back over all previous threads and posts can someone bring me up to speed with the Bluetooth status, are the drivers there to support a USB dongle?
thanks
There are currently 3955 users online. 1 members and 3954 guests.
