OLD - UG802 2dark4u/Finless custom ROM version 1.7
You can do the libstagefright.so yourself super easy!
Your rooted so just copy that over to /system/lib and set permissions. Done!
You do not need a rom to get this.
Originally posted by Gaenya View PostHi bob and thanks for your answer, i tried that and when the device didnt booted, it just got to the boot logo and stayed there for 2 hours until it disconnected and flashed it again...
My devices is a rikomagic mk802 III if it mathers.
THanks.
I would like to use libstagefright.so too, but I can´t finish with bricked device.
THX
but I have another stupid question - how to get CWM into my MK802III with Finless ROM 1.7?
Or is already integrated?
Thanks again.
I will try it.
Hi Bob,
I have tried "reboot to recovery" option in reboot app from Finless ROM 1.7, but after restart device I see only "dead android" - https://www.box.com/s/oj4oycvy719boarh9f76.
So I guess, I need to install Fun's CWM.
Hi to everyone on the forum. This is my first post so be gentle. I have a Mk809ii device that was runnng on finless 1.5 rom. I tried to copy libstagefright.so to the lib folder from the XBMC forum but as a previous poster had already discovered when I rebooted the device it just sticks on the boot up screen. There is a rest button on the device and when held during power up the screen appears with a lying down droid.I was hoping it would put the device into flash mode but it doesn't appear so.
I have tried shorting pins 6/7 as per the MK809 recovery info but device still not recognised although the PC does make a sound as if a device is detected. Pleas could some help with any possible solutions as to how to recover the device. The procedure for shorting the pins implies , short pins 6/7 of flash chip, connect otg cable to pc and device (I presume to the data socket not power) leave pins shorted for 3-5 sec and device should now be found with unkown driver symbol. Am i doing this correctly. Sorry if this is in the incorrect forum but appears relavent to the libstagefright.so issue.
There are currently 4363 users online. 1 members and 4362 guests.
