OLD - UG802 2dark4u/Finless custom ROM version 1.7
Lost original the Setting App
I somehow managed to delete the original "simple" Setting app and cannot flash the ROM now as I can't get the U802 into Flash mode - without the simple Setting app I can't switch between Mass Storage and MTP mode (step 7) => "Flash mode failed" error
Is there any place where I can download the original Setting apk or another way to switch from Mass Storage to MTP and back?
TIA
Chimok
TIA
Chimok
Use the reboot button and boot to bootloader
TIA
Chimok
Originally posted by bads View PostFlashed with stock kernel and sound works.
Anyone have same problem? Any clues how to work this around?
Thanx
On different TV people getting different results on some TV sound won't work but on some no problems with sound.
Originally posted by gabb View PostUse the reboot button and boot to bootloader
After powering the stick on for a second time it went into Flash mode.
I have flashed the 1080 not overclocked version and everything works fine now.
Finless and 2d4u did a great job!
Ok I also tested the new rom I started with:
kernel_1080_CPU1272_GPU466_RAM1120.img = Overclocked CPU@1272, GPU@466, Ram@1120
Wow 1080p vids look sharp and nice! But I had also the following already mentioned problems:
- flickering artifacts in 1080p
- sound not working stable
- WiFi reception less stable and less throughput
I also tried a 2a Ipad usb adapter but no change. So I switched back to stock and then sound/wifi were perfect again and no flickering artifacts anymore. Hopefully it can be fixed because it was a pleasure to look at!
Thx again!
IMPORTANT! Please read this!
Originally posted by Auron View PostFor people using the 'dual boot' capable recovery.img from AndrewDB for the Ubuntu pre-alpha, can we just replace recovery.img with the one from that, rather than flashing it twice?
Thanks for the work on this ROM
1. When you Flash Bob's ROM for the first time, the Misc partition is setup so that the UG802 reboots into standard recovery and runs a short script that formats the cache, etc. The last step of this script is to clear the Misc partition so that on your next reboot, the UG802 boots into Android normally.
2. If you flash my Linux kernel in the recovery partition at the same time as Bob's ROM, the short script never runs, Misc never gets cleared and you'll be stuck booting into the Linux kernel forever, until you "unbrick" the UG802 - which requires opening the case, etc (it's no big deal, but still a small PITA).
So the correct way to go here is:
1. Flash Bob's ROM, let it reboot into recovery, run the script, and reboot into Android.
2. Make sure Android runs fine.
3. Install the Linux kernel and then you can dual boot Bob's excellent Android ROM and Ubuntu Linux without any problems.
Flickering
Same here, flashed with kernel_1080_CPU1272_GPU466_RAM1120.img and noticed constant flickering at 1080p 60 hz.
Changed to 1080p 50 hz and the flickering was less. Then changed to 1080p 24 hz and it was very minimal but still there.
Finally I flashed with 720p Kernel and flickering completely disappeared.
Bob any help to fix this is appreciated.
heat sink
Hello . I flashed kernel_720_CPU1272_GPU466_RAM1120 and everything works great, sound,wifi only my ethernet usb adapter doesn't work. i made heatsink from old graphic card(heatsink 40x40mm) for pc and glued with termal glue Artic Silver two component adhesive.cooling fan is 12V 0.7W 40x40mm. Please tell me 2dark4u/Finless is my heatsink ok for
kernel_720_CPU1608_GPU466_RAM1120? i'm affraid to burn ug802. i make donate 2 weeks ago and next donate coming soon. my paypal card expired 2 days ago.
i have usb hub4x1 d link with power supply.
1.http://imageshack.us/photo/my-images...201215954.jpg/
2.http://imageshack.us/photo/my-images...201232517.jpg/
3.http://imageshack.us/photo/my-images...202004714.jpg/
Many regards from Croatia.Last edited by spaky; 12-02-2012, 01:05.
There are currently 2925 users online. 2 members and 2923 guests.
