In applying the Custom ROM you lose your warranty
Attention! Not suitable for ARNOVA 8G 4Gb
Updated version Custom ROM v.4.1s
Differences firmware.
- Section /system transformed into a format the ext3 file system that, allows to edit, add and delete files in it.
- Set aside for user data 1Gb memory. This will allow install more applications.
- Updated some applications to latest version, add Google appliacation.
Attention! Flash removes all with built-in flash memory (format).
Keep everything you need to SD-card, which perered firmware remov it from the tablet.
Installation instructions in the archive along with the program and drivers.
ROM -> Custom Rom for ARNOVA 8G2 8Gb v4.1s by Sowa (100 Mb)
Rolling back from the version 4s & 5s with only Rk29BatchTools through the button "Restore"
User data during installation are removed.
Dump the standard ROM AN8G2_rkdump.7z
