Custom ROM For ARNOVA 8G2 [ROOT, Market, Google apps, ext3, 1Gb user space]
Anyway to sort the damn g sensors out on this rom????? Cannot use games or apps that use tilt control at all....
Also could we increase user apps area too and sort out issue with a physical microsd card inserted messing up apps that have data stored in mnt/external/sdcard..... Defeats the object of having an sd slot to increase storage etc....
Originally posted by lohtse View PostAnyway to sort the damn g sensors out on this rom????? Cannot use games or apps that use tilt control at all....
Let's wait for a firmware update from the developers.
All other tablets Series G2 have already received such updates.
Most recalls in support of the arnovatech.com deficiencies.Archos 7c HT (My Custom ROM production) -> ARNOVA 8G2 8Gb (My modification MorkaMod JB v.1.2)
Chinese STAR A5000=>Star N8000 (My Custom ROM production)
Originally posted by Sowa View PostAll the actions you do at your own risk!
In applying the Custom ROM you lose your warranty
Attention! Not suitable for ARNOVA 8G 4Gb
Updated version Custom ROM v.4.1s
Differences firmware.
- Section /system transformed into a format the ext3 file system that, allows to edit, add and delete files in it.
- Set aside for user data 1Gb memory. This will allow install more applications.
- Updated some applications to latest version, add Google appliacation.
Attention! Flash removes all with built-in flash memory (format).
Keep everything you need to SD-card, which perered firmware remov it from the tablet.
Installation instructions in the archive along with the program and drivers.
ROM -> Custom Rom for ARNOVA 8G2 8Gb v4.1s by Sowa (100 Mb)
Rolling back from the version 4s & 5s with only Rk29BatchTools through the button "Restore"
User data during installation are removed.
Dump the standard ROM AN8G2_rkdump.7z
thankyou very much
Originally posted by scottishpeanut View PostFantastic ROM, thanks SOWA.
Just a quick question, the market allows me access but when I go to download I get error messages (quite a few different codes). This is my first time at flashing etc, is this normal?
Try wiping the data for the market and restarting the app.
Blinky
Sent from my Arnova using Tapatalk
Originally posted by scottishpeanut View PostHi, just another quick query, the rom runs fine (occasionally unstable) but the main problem is that when the tablet runs out of battery or I switch it off, I cant get it past the android screen when restarting it, or even resetting it. Is this common with mods? Thanks again
Sorry can't be more help than this.
how do i download driver for 8g2? thanks for your help in advance.
Originally posted by Bedtime4u View Posthow do i download driver for 8g2? thanks for your help in advance.Archos 7c HT (My Custom ROM production) -> ARNOVA 8G2 8Gb (My modification MorkaMod JB v.1.2)
There are currently 3663 users online. 1 members and 3662 guests.
