NEOCR 2.0 for 10G3 *Update NEOCR 2.1*
    Here is it the NEOCM Rom now called NEOCR for 10G3.
    Newest JB Source with fixed.
    ext4 system
    Rotation Fix
    Akku Fix
    4.2 Stock Launcher
    Snakekiller GUI Thx Buddy
    To Install get the Rom from here:
    * Please Download the NEW VERSION NEOCM2.1 all Fixes Include *
    You must also Download the Fix for the Parameter File & Loader and the Rotation Issue.
    Thx to Tattman65, rrileypm, kididaho for Testing and finding the right Patch for Rotation.
    Place it in rockdev.
    Extract it and take the NAND Fix to SD-Card
    Now Flash the Rom.
    1. Open RkUtil with Admin right´s
    2. Click on Loader and Erase IDB
    3. Unclick Loader
    4. Click Run
    5. After Flashing you are in Recovery Execute the fix.
    6. Reboot
    7. Wait about 4 min.
    8. Reboot
    9. Disable Hardware Overlay
    10.: Set GPU to yes
    11.: Have Fun !
    Neomode
    Update Tomorrow comes the Final ROM.
    NEOCR 2.0 for 10G3 -Jelly Bean- 2012.12.07
    I'm on it. I'll report after the flash.
    Randy
      well done buddy
      if you love my work please buy a coffee
      <form action="https://www.paypal.com/cgi-bin/webscr" method="post">https://www.paypalobjects.com/en_GB/i/scr/pixel.gif
      </form>
        Erase IDB stops at 1998 every time...done it 5 times now. Is that OK?
        Randy
          Offsets fail on all the img files.
          All of the offset fields are empty on my loader tool.
          Randy
            OK, I went to a different PC...my 32 bit Win7 notebook...and successfully completed erasing IDB, but the offsets fail still on all of the img files.
            Randy
              Hey Neomode, what you got for me?
              Randy
                I understand, you are taking care of another Spammer. Whenever you get a chance...I need a little help, here.
                Randy
                  and if you set the pads for every part mannually ?
                  </form>
                    I tried setting the paths manually, but still had the same errors on all of the img files. That's why I switched to a different pc to see if the paths were the problem.
                    Randy
                      and if you use the snakegenmod flash tool with his files?
                      </form>
                        there is also no parameter file in place in the image folder and from what i could tell the image folder could not be found by the flash tool . the image folder is not set up like all the others that i have . theres no loader or parameter file in place .
                        freaktab art developer if you like my work please buy me a pepsi
                          I havent tried that. I'll give that a try.
                          Randy
                            there is not a parameter file in the image folder it won't work . remember when we went through this when Bob left out the file ?
                              use the flash tool otherwise with the parameter file from the previous test version.
                              but with the new img's.
                              </form>
