NEOCR 2.0 for 10G3 *Update NEOCR 2.1*
    NEOCR 2.0 for 10G3 -Jelly Bean- 2012.12.07
    On mine, the battery circle isn't updating but the numbers in the notification tab are accurate. I'll reboot and see if it changes.
    Randy
      so far my circle has updated from 43 percent when i plugged in to 74 percent now .
      that was after first reboot.
      freaktab art developer if you like my work please buy me a pepsi
        My circle is 100%, but it is really 91%.
        Randy
          Originally posted by neomode View Post
          Thx Man !!
          It was a Long way to there.
          By the Way how was the Download Speed from our FTP Server ?
          Neo
          download speed was pretty quick neo .
            mine seems to be off by 1 percent .
              Ok Tatty, I must have flashed something different. Now I have rotation problems...stuck in portrait.
              I haven't tried the whole package Neomode uploaded yet. Would you advise that?
              Randy
                hey sorry just seen your post have you done anything yet ?
                  ok well i just now tried rotation for the first time i have none .
                  which truthfully is fine by me but....... it needs to be looked at .
                    the package with the replacement pararmeter and loader should be fine .
                      Yep, I reflashed using the one Neomode uploaded and got the same error.
                      Then I flashed using the kit named NEOCM10_G3 after I copied all the files into the image folder.
                      Everything flashed OK, I just had to try 4 times to get IDB to erase all the way.
                      Now I'm waiting the 4 minutes before reboot.
                      Before, I didn't change the HW overlay or the GPU setting. I don't know if that made any difference.
                      Randy
                        i did not change hw overlay or anything hell i did not see it to tell the truth .
                          ok so i just tried a app that i knew would change rotation and when it flipped i had to reboot to get it back
                          landscape ..
                            Got battery charging until green light comes on...then I'll see if the icon updates ok.
                            I guess the common issues are that, and screen rotation. Whenever I run an app that is in portrait, my tablet sticks in portrait until I reboot. PITA!!!!
                            Randy
                              yeah , i done this , got battery callibrator ( the free one ) and waited till the green lite ,, display said
                              100 percent battery icon changed to blue .. launched battery calibrator app it said 97 percent please wait till 100 . so it's close to right .
                                well the battery icon can't seem to make up it's mind .
                                i let it get down to 85 % then plugged up and it jumped back up to 100% in about a minute .
                                and in notification tray it says 94 %
                                so i'm gonna let it run for awhile and see what happens .
